am 18.09.2021 16:32
Hello all,
sorry for writing in English. I'm having an issue with the WAN DHCP of my private router NETGEAR Nighthawk X6S when connected to the kabelmodem in Bridge-mode
I have activated it on the website vodafone.de, connected the router to LAN1 but the router couldn't get an IP via DHCP
Shall I set one statically? Does it need authentication?
Thank you,
am 26.09.2021 10:20
yes, DHCP is the right option. You have to configure it without any authentication.
Maybe also restart the cable router again (power off and power on again), if you change something regarding the settings on the WAN interface on your Netgear router.
18.09.2021 16:44 - bearbeitet 18.09.2021 16:46
try to power cycle the Vodafone Station and do not connect any other devices, only your router to lan 1
am 20.09.2021 14:07
Hello macmiranda,
in which federal state do you live?
The bridge mode could be activated without any problems, or was there an error message?
Many greetings
Jana
am 26.09.2021 09:58
@Jana478 schrieb:Hello macmiranda,
Many greetings
Jana
Yes, it was activated without any warnings. I live in Berlin
am 26.09.2021 10:00
@RobertP schrieb:try to power cycle the Vodafone Station and do not connect any other devices, only your router to lan 1
Thank you, I'll try that.
Would you be able to confirm then that DHCP is the correct option for the WAN IP?
am 26.09.2021 10:20
