am 27.05.2022 12:16
My problem is exactly the same as in this post.
https://ipv6.google.com is not loading at all and some of the apps also are not loading. Everything works fine on mobile data.
am 27.05.2022 18:18
Hello sushantsoni1,
which apps does it affect exactly on which phone?
In which state do you live?
Greetings Moni
am 12.06.2023 13:04
I am facing the exact same problem. Did you find the solution?
Thanks
