Kempten: Ausfall TV und Radio über Kabel
am 04.08.2021 11:58
Hallo zusammen!
Wir haben das Problem, sobald ein Gerät das über lan am router angeschlossen ist, Startet oder etwas downloaded, der Router seinen DSL link verliert.
Was dazu führt, das wir im Homeoffice zb. nicht vernünftig arbeiten können.
Gibt es dorthin gehend eine Lösung ?
Protokoll :
[INFO][System] 08-04-2021 09:57:27 FSM---- Switch to Connect State.
[INFO][WAN] 08-04-2021 09:57:26 WAN VDSL-DT has been stopped, please check your PHY link
[INFO][LAN] 08-04-2021 09:57:26 LAN sending RA to ff02::1
[INFO][WAN] 08-04-2021 09:57:26 Stopping VDSL interface OK.
[INFO][WAN] 08-04-2021 09:57:26 Stop WAN 10 DSL Connection
[INFO][System] 08-04-2021 09:57:25 Starting HTTP redirect OK.
[INFO][DNS] 08-04-2021 09:57:25 DNSMasq proxy server enable redirect
[INFO][System] 08-04-2021 09:57:25 Stopping NTP Client OK.
[INFO][VoIP] 08-04-2021 11:57:25 VoIP WAN down, no available connection
[INFO][VoIP] 08-04-2021 11:57:25 Remove interface wan_id is 10,wan type 1.
[INFO][VoIP] 08-04-2021 11:57:25 bud data ipv4 wan status -1,ipv6 wan status -1
[INFO][VoIP] 08-04-2021 11:57:25 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 10,is_ipv6 = 0,default_wan_id= 10
[INFO][VoIP] 08-04-2021 11:57:25 ===start stop voice wan
[INFO][DNS] 08-04-2021 11:57:25 Internet DNS deactived.
[INFO][LAN] 08-04-2021 11:57:25 LAN sending RA to ff02::1
[INFO][System] 08-04-2021 11:57:24 Starting NTP Client OK.
[INFO][System] 08-04-2021 11:57:24 Sync up with NTP Server failed.
[INFO][System] 08-04-2021 09:57:24 Stopping NTP Client OK.
[INFO][VoIP] 08-04-2021 11:57:24 VoIP WAN down, no available connection
[INFO][VoIP] 08-04-2021 11:57:24 Remove interface wan_id is 10,wan type 1.
[INFO][VoIP] 08-04-2021 11:57:24 bud data ipv4 wan status -1,ipv6 wan status -1
[INFO][VoIP] 08-04-2021 11:57:24 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 10,is_ipv6 = 0,default_wan_id= 10
[INFO][VoIP] 08-04-2021 11:57:24 ===start stop voice wan
[INFO][WAN] 08-04-2021 11:57:24 WAN VDSL-DATA has been stopped, please check your PHY link
[INFO][DNS] 08-04-2021 11:57:23 Internet DNS Servers 176.95.16.250, 176.95.16.251.
[INFO][DNS] 08-04-2021 11:57:23 Internet DNS ready.
[INFO][DNS] 08-04-2021 11:57:23 Internet DNS deactived.
[INFO][System] 08-04-2021 11:57:23 Starting NTP Client OK.
[INFO][System] 08-04-2021 11:57:23 Sync up with NTP Server failed.
[INFO][System] 08-04-2021 09:57:23 Stopping NTP Client OK.
[INFO][VoIP] 08-04-2021 11:57:23 VoIP WAN down, no available connection
[INFO][VoIP] 08-04-2021 11:57:23 Remove interface wan_id is 10,wan type 1.
[INFO][VoIP] 08-04-2021 11:57:23 bud data ipv4 wan status -1,ipv6 wan status -1
[INFO][VoIP] 08-04-2021 11:57:23 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 10,is_ipv6 = 1,default_wan_id= 10
[INFO][VoIP] 08-04-2021 11:57:23 ===start stop voice wan
[INFO][WAN] 08-04-2021 11:57:23 Stop WAN 8 DSL Connection
[INFO][LAN] 08-04-2021 11:57:22 LAN sending RA to ff02::1
[INFO][DNS] 08-04-2021 11:57:22 Internet DNS Servers 176.95.16.250, 176.95.16.251.
[INFO][DNS] 08-04-2021 11:57:22 Internet DNS ready.
[INFO][DNS] 08-04-2021 11:57:22 Internet DNS deactived.
[INFO][WAN] 08-04-2021 11:57:22 Stop WAN 10 IP Connection
[INFO][WAN] 08-04-2021 11:57:22 IPTV WAN11 DeActivated!
[INFO][WAN] 08-04-2021 11:57:22 bud update WAN11 status to 0.
[INFO][WAN] 08-04-2021 11:57:22 Stop WAN 4 DSL Connection
[INFO][LAN] 08-04-2021 11:57:21 LAN sending RA to ff02::1
[EMERG][WAN] 08-04-2021 11:57:21 DSL link down.
[WARNING][Firewall] 08-04-2021 11:57:21 src=192.168.2.103 DST=17.57.146.165 PROTO=TCP SPT=52920 DPT=5223 MARK=0x1 DROP
[WARNING][Firewall] 08-04-2021 11:57:21 src=192.168.2.101 DST=142.250.185.138 PROTO=TCP SPT=54734 DPT=443 MARK=0x3 DROP
[WARNING][Firewall] 08-04-2021 11:57:21 src=192.168.2.101 DST=160.44.193.33 PROTO=TCP SPT=53404 DPT=443 MARK=0x3 DROP
[WARNING][Firewall] 08-04-2021 11:57:21 src=192.168.2.101 DST=160.44.193.33 PROTO=TCP SPT=53402 DPT=443 MARK=0x3 DROP
[WARNING][Firewall] 08-04-2021 11:57:21 src=192.168.2.104 DST=185.136.68.145 PROTO=TCP SPT=57491 DPT=443 MARK=0x3 DROP
[WARNING][Firewall] 08-04-2021 11:57:21 src=192.168.2.104 DST=155.133.252.54 PROTO=TCP SPT=57482 DPT=27039 MARK=0x1 DROP
[WARNING][Firewall] 08-04-2021 11:57:21 src=192.168.2.104 DST=162.254.198.104 PROTO=TCP SPT=57483 DPT=27035 MARK=0x1 DROP
[WARNING][Firewall] 08-04-2021 11:57:21 src=192.168.2.104 DST=155.133.226.75 PROTO=TCP SPT=57480 DPT=27031 MARK=0x1 DROP
[INFO][LAN] 08-04-2021 11:51:51 LAN sending RA to ff02::1
[INFO][System] 08-04-2021 11:50:15 User 'vodafone' login successfully via HTTP from 192.168.2.102
[INFO][VoIP] 08-04-2021 11:43:15 Switch to primary proxy server arcor.de on line 0
[INFO][LAN] 08-04-2021 11:43:04 LAN sending RA to ff02::1
[INFO][LAN] 08-04-2021 11:42:48 LAN sending RA to ff02::1
[INFO][LAN] 08-04-2021 11:42:32 LAN sending RA to ff02::1
[INFO][System] 08-04-2021 09:42:28 Sync up with NTP Server successfully.
[INFO][VoIP] 08-04-2021 09:42:20 Send data/single wan update to VGW,wan id 10,ifName is ppp10,ipv4 address 88.75.99.147,ipv6 address ,default_wan_id 10,wan type 1
[INFO][VoIP] 08-04-2021 09:42:20 line 371 ,wan 10 start do data wan up
[INFO][VoIP] 08-04-2021 09:42:20 wanipv6 = ,size = 0
[INFO][VoIP] 08-04-2021 09:42:20 Voice binding wan_id is 10,default_wan_id is 10
[INFO][VoIP] 08-04-2021 09:42:20 Voice binding wan_id is 10,default_wan_id is 10,is_ipv6 = 0
[INFO][VoIP] 08-04-2021 09:42:20 wan 10 service_type = DATA,VOIP,MGNT,IPTV bud_voip_wan_id = 10
[INFO][VoIP] 08-04-2021 09:42:20 Interface wan_ip is 88.75.99.147, wan_ip_v6 ,is_ipv6 0 wan up id 10
[INFO][LAN] 08-04-2021 09:42:19 adapter hardware address 04:71:53:8a:ac:b0
[INFO][LAN] 08-04-2021 09:42:19 adapter index 18
[INFO][LAN] 08-04-2021 09:42:19 br0 (our ip) = 192.168.2.1
[INFO][LAN] 08-04-2021 09:42:19 Attaching option timezone to list
[INFO][LAN] 08-04-2021 09:42:19 Attaching option t2 to list
[INFO][LAN] 08-04-2021 09:42:19 Attaching option t1 to list
[INFO][LAN] 08-04-2021 09:42:19 Attaching option lease to list
[INFO][LAN] 08-04-2021 09:42:19 Attaching option dns to existing member of list
[INFO][LAN] 08-04-2021 09:42:19 Attaching option dns to list
[INFO][LAN] 08-04-2021 09:42:19 adapter hardware address 04:71:53:8a:ac:c0
[INFO][LAN] 08-04-2021 09:42:19 adapter index 19
[INFO][LAN] 08-04-2021 09:42:19 br1 (our ip) = 192.168.3.1
[INFO][LAN] 08-04-2021 09:42:19 Attaching option router to list
[INFO][LAN] 08-04-2021 09:42:19 Attaching option subnet to list
[INFO][LAN] 08-04-2021 09:42:19 error on select
[INFO][LAN] 08-04-2021 09:42:19 udhcp server receive signal 12
[INFO][LAN] 08-04-2021 09:42:19 Attaching option hostname to list
[INFO][LAN] 08-04-2021 09:42:19 Attaching option domain to list
[INFO][System] 08-04-2021 09:42:18 Starting MCPD OK.
[INFO][System] 08-04-2021 09:42:18 Stopping MCPD OK.
[INFO][UMTS] 08-04-2021 09:42:18 IPhone DNS Policy actived
[INFO][VoIP] 08-04-2021 09:42:18 276 start wan service Voice binding wan_id is 10
[INFO][VoIP] 08-04-2021 09:42:18 Voice binding wan_id is 10
[INFO][System] 08-04-2021 09:42:18 Starting NTP Client OK.
[INFO][System] 08-04-2021 09:42:18 Sync up with NTP Server failed.
[INFO][System] 08-04-2021 09:42:18 Stopping NTP Client OK.
[INFO][Firewall] 08-04-2021 09:42:17 PortMapping Rules have been flushed on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:42:17 DMZ Rules has been flushed on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:42:17 Static NAT Rules have been flushed on WAN VDSL-DT.
[INFO][System] 08-04-2021 09:42:17 Stopping HTTP redirect OK.
[INFO][DNS] 08-04-2021 09:42:17 DNSMasq proxy server disable redirect
[ERROR][DNS] 08-04-2021 09:42:17 failed to load names from /tmp/dnsmasq_hosts.d/data_hosts: No such file or directory
[INFO][DNS] 08-04-2021 09:42:17 Internet DNS Servers 176.95.16.250, 176.95.16.251.
[INFO][DNS] 08-04-2021 09:42:17 Internet DNS ready.
[WARNING][DNS] 08-04-2021 09:42:17 ignoring nameserver 127.0.0.1 - local interface
[WARNING][DNS] 08-04-2021 09:42:17 ignoring nameserver ::1 - local interface
[INFO][DNS] 08-04-2021 09:42:17 Starting DNSMasq proxy server OK.
[INFO][DNS] 08-04-2021 09:42:17 Stopping DNSMasq proxy OK.
[INFO][LAN] 08-04-2021 09:42:16 LAN sending RA to ff02::1
[INFO][DNS] 08-04-2021 09:42:16 DNSMasq proxy server disable redirect
[INFO][VoIP] 08-04-2021 09:42:14 ignore useless wan down
[INFO][VoIP] 08-04-2021 09:42:14 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 8,is_ipv6 = 0,default_wan_id= 10
[INFO][VoIP] 08-04-2021 09:42:14 ===start stop voice wan
[INFO][UMTS] 08-04-2021 09:42:14 IPhone DNS Policy actived
[INFO][VoIP] 08-04-2021 09:42:14 Remove interface wan_id is 10,wan type 2.
[INFO][VoIP] 08-04-2021 09:42:14 VoIP WAN down, Voice trying to run in backup mode, try binding wan_id is 10
[INFO][VoIP] 08-04-2021 09:42:14 bud data ipv4 wan status 10,ipv6 wan status -1
[INFO][VoIP] 08-04-2021 09:42:14 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 10,is_ipv6 = 0,default_wan_id= 10
[INFO][System] 08-04-2021 09:42:14 Starting MCPD OK.
[INFO][VoIP] 08-04-2021 09:42:14 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 8,is_ipv6 = 1,default_wan_id= 10
[INFO][System] 08-04-2021 09:42:13 Stopping MCPD OK.
[INFO][WAN] 08-04-2021 09:42:12 Stop WAN 8 IP Connection
[INFO][System] 08-04-2021 09:42:11 FSM---- Switch to Connect State.
[INFO][DNS] 08-04-2021 09:42:11 Internet DNS Servers 176.95.16.250, 176.95.16.251.
[INFO][DNS] 08-04-2021 09:42:10 Internet DNS ready.
[INFO][DNS] 08-04-2021 09:42:10 Internet DNS Servers 176.95.16.250, 176.95.16.251.
[INFO][DNS] 08-04-2021 09:42:10 Internet DNS deactived.
[WARNING][WAN] 08-04-2021 09:42:10 WAN default route add to ppp10 gateway 84.59.211.1.
[INFO][WAN] 08-04-2021 09:42:10 Data WAN11 Activated!
[INFO][WAN] 08-04-2021 09:42:10 bud update WAN11 status to 2.
[WARNING][WAN] 08-04-2021 09:42:10 WAN VDSL-DT is up, mode is PPPoE, IP is 88.75.99.147.
[WARNING][WAN] 08-04-2021 09:42:10 WAN VDSL-DT is down.
[INFO][LAN] 08-04-2021 09:42:10 LAN sending RA to ff02::1
[INFO][WAN] 08-04-2021 09:42:10 PPP CHAP MD5 authentication is successful on WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:42:10 PPPOE PADS has been received from WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:42:10 PPPOE PADR has been sent from WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:42:10 PPPOE PADO has been received from WAN VDSL-DT, BRAS name is LUHCOS00101.
[INFO][WAN] 08-04-2021 09:42:10 PPPOE PADI has been sent from WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:42:10 PPPOE PADI has been sent from WAN VDSL-DATA
[INFO][System] 08-04-2021 09:42:02 FSM---- Switch to Connect State.
[INFO][WAN] 08-04-2021 09:41:53 PPPOE PADI has been sent from WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:41:53 PPPOE PADI has been sent from WAN VDSL-DATA
[INFO][System] 08-04-2021 09:41:52 FSM---- Switch to Connect State.
[INFO][System] 08-04-2021 09:41:42 FSM---- Switch to Connect State.
[INFO][System] 08-04-2021 09:41:33 FSM---- Switch to Connect State.
[INFO][LAN] 08-04-2021 09:41:32 LAN sending RA to ff02::1
[EMERG][WAN] 08-04-2021 09:41:29 DSL link up.
[EMERG][WAN] 08-04-2021 09:41:27 DSL link up.
[EMERG][WAN] 08-04-2021 09:41:26 DSL link up.
[EMERG][WAN] 08-04-2021 09:41:25 DSL link up.
[EMERG][WAN] 08-04-2021 09:41:23 DSL link up.
[EMERG][WAN] 08-04-2021 09:41:22 DSL link up.
[INFO][System] 08-04-2021 09:41:22 FSM---- Switch to Connect State.
[EMERG][WAN] 08-04-2021 09:41:21 DSL link up.
[EMERG][WAN] 08-04-2021 09:41:19 DSL link up.
[EMERG][WAN] 08-04-2021 09:41:18 DSL link up.
[EMERG][WAN] 08-04-2021 09:41:17 DSL link up.
[INFO][LAN] 08-04-2021 09:41:16 LAN sending RA to ff02::1
[EMERG][WAN] 08-04-2021 09:41:15 DSL link up.
[EMERG][WAN] 08-04-2021 09:41:14 DSL link up.
[EMERG][WAN] 08-04-2021 09:41:13 DSL link up.
[INFO][System] 08-04-2021 09:41:12 FSM---- Switch to Connect State.
[EMERG][WAN] 08-04-2021 09:41:11 DSL link up.
[EMERG][WAN] 08-04-2021 09:41:07 DSL link up.
[EMERG][WAN] 08-04-2021 09:41:06 DSL link up.
[EMERG][WAN] 08-04-2021 09:41:05 DSL link up.
[EMERG][WAN] 08-04-2021 09:41:03 DSL link up.
[INFO][System] 08-04-2021 09:41:03 FSM---- Switch to Connect State.
[INFO][LAN] 08-04-2021 09:41:00 LAN sending RA to ff02::1
[INFO][WAN] 08-04-2021 09:40:57 PPPOE PADI has been sent from WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:40:56 PPPOE PADI has been sent from WAN VDSL-DATA
[INFO][System] 08-04-2021 09:40:54 FSM---- Switch to Connect State.
[INFO][LAN] 08-04-2021 09:40:44 LAN sending RA to ff02::1
[INFO][System] 08-04-2021 09:40:44 FSM---- Switch to Connect State.
[INFO][WAN] 08-04-2021 09:40:44 PPPOE PADI has been sent from WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:40:43 PPPOE PADI has been sent from WAN VDSL-DATA
[INFO][LAN] 08-04-2021 09:40:43 LAN sending RA to ff02::1
[INFO][WAN] 08-04-2021 09:40:43 Start WAN 10 IP Connection
[INFO][WAN] 08-04-2021 09:40:43 WAN VDSL-DT has been started, PHY link up
[INFO][WAN] 08-04-2021 09:40:43 Start WAN 8 IP Connection
[INFO][WAN] 08-04-2021 09:40:43 WAN VDSL-DATA has been started, PHY link up
[INFO][WAN] 08-04-2021 09:40:42 Start WAN 10 DSL Connection
[INFO][LAN] 08-04-2021 09:40:42 LAN sending RA to ff02::1
[INFO][WAN] 08-04-2021 09:40:42 Starting VDSL interface OK.
[INFO][WAN] 08-04-2021 09:40:42 Start WAN 8 DSL Connection
[INFO][WAN] 08-04-2021 09:40:41 Start WAN 4 DSL Connection
[EMERG][WAN] 08-04-2021 09:40:41 DSL link up.
[INFO][System] 08-04-2021 09:40:34 FSM---- Switch to Connect State.
[INFO][System] 08-04-2021 09:40:26 FSM---- Switch to Connect State.
[INFO][System] 08-04-2021 09:40:16 FSM---- Switch to Connect State.
[INFO][System] 08-04-2021 09:40:07 FSM---- Switch to Connect State.
[INFO][System] 08-04-2021 09:39:57 FSM---- Switch to Connect State.
[INFO][System] 08-04-2021 09:39:48 FSM---- Switch to Connect State.
[INFO][System] 08-04-2021 09:39:36 FSM---- Switch to Connect State.
[INFO][LAN] 08-04-2021 09:39:32 LAN sending RA to ff02::1
[INFO][System] 08-04-2021 09:39:25 FSM---- Switch to Connect State.
[INFO][LAN] 08-04-2021 09:39:16 LAN sending RA to ff02::1
[INFO][System] 08-04-2021 09:39:15 FSM---- Switch to Connect State.
[INFO][System] 08-04-2021 09:39:04 FSM---- Switch to Connect State.
[INFO][LAN] 08-04-2021 09:39:00 LAN sending RA to ff02::1
[INFO][System] 08-04-2021 09:38:55 FSM---- Switch to Connect State.
[EMERG][WAN] 08-04-2021 09:38:51 DSL link down.
[INFO][System] 08-04-2021 09:38:45 FSM---- Switch to Connect State.
[INFO][WAN] 08-04-2021 09:38:44 WAN VDSL-DT has been stopped, please check your PHY link
[INFO][LAN] 08-04-2021 09:38:43 LAN sending RA to ff02::1
[INFO][WAN] 08-04-2021 09:38:43 Stopping VDSL interface OK.
[INFO][WAN] 08-04-2021 09:38:43 Stop WAN 10 DSL Connection
[INFO][System] 08-04-2021 09:38:43 Starting HTTP redirect OK.
[INFO][DNS] 08-04-2021 09:38:43 DNSMasq proxy server enable redirect
[INFO][System] 08-04-2021 09:38:43 Stopping NTP Client OK.
[INFO][VoIP] 08-04-2021 09:38:43 VoIP WAN down, no available connection
[INFO][VoIP] 08-04-2021 09:38:43 Remove interface wan_id is 10,wan type 1.
[INFO][VoIP] 08-04-2021 09:38:43 bud data ipv4 wan status -1,ipv6 wan status -1
[INFO][VoIP] 08-04-2021 09:38:43 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 10,is_ipv6 = 0,default_wan_id= 10
[INFO][VoIP] 08-04-2021 09:38:43 ===start stop voice wan
[INFO][DNS] 08-04-2021 09:38:42 Internet DNS deactived.
[INFO][LAN] 08-04-2021 09:38:42 LAN sending RA to ff02::1
[INFO][System] 08-04-2021 09:38:42 Starting NTP Client OK.
[INFO][System] 08-04-2021 09:38:42 Sync up with NTP Server failed.
[INFO][System] 08-04-2021 09:38:42 Stopping NTP Client OK.
[INFO][VoIP] 08-04-2021 09:38:42 VoIP WAN down, no available connection
[INFO][VoIP] 08-04-2021 09:38:42 Remove interface wan_id is 10,wan type 1.
[INFO][VoIP] 08-04-2021 09:38:42 bud data ipv4 wan status -1,ipv6 wan status -1
[INFO][VoIP] 08-04-2021 09:38:42 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 10,is_ipv6 = 0,default_wan_id= 10
[INFO][VoIP] 08-04-2021 09:38:42 ===start stop voice wan
[INFO][DNS] 08-04-2021 09:38:41 Internet DNS Servers 176.95.16.250, 176.95.16.251.
[INFO][DNS] 08-04-2021 09:38:41 Internet DNS ready.
[INFO][DNS] 08-04-2021 09:38:41 Internet DNS deactived.
[INFO][System] 08-04-2021 09:38:41 Starting NTP Client OK.
[INFO][System] 08-04-2021 09:38:41 Sync up with NTP Server failed.
[INFO][System] 08-04-2021 09:38:41 Stopping NTP Client OK.
[INFO][VoIP] 08-04-2021 09:38:40 VoIP WAN down, no available connection
[INFO][VoIP] 08-04-2021 09:38:40 Remove interface wan_id is 10,wan type 1.
[INFO][VoIP] 08-04-2021 09:38:40 bud data ipv4 wan status -1,ipv6 wan status -1
[INFO][VoIP] 08-04-2021 09:38:40 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 10,is_ipv6 = 1,default_wan_id= 10
[INFO][VoIP] 08-04-2021 09:38:40 ===start stop voice wan
[INFO][WAN] 08-04-2021 09:38:40 Stop WAN 8 DSL Connection
[INFO][DNS] 08-04-2021 09:38:40 Internet DNS Servers 176.95.16.250, 176.95.16.251.
[INFO][DNS] 08-04-2021 09:38:40 Internet DNS ready.
[INFO][LAN] 08-04-2021 09:38:40 LAN sending RA to ff02::1
[INFO][DNS] 08-04-2021 09:38:40 Internet DNS deactived.
[INFO][WAN] 08-04-2021 09:38:40 Stop WAN 10 IP Connection
[INFO][WAN] 08-04-2021 09:38:40 IPTV WAN11 DeActivated!
[INFO][WAN] 08-04-2021 09:38:40 bud update WAN11 status to 0.
[INFO][WAN] 08-04-2021 09:38:39 Stop WAN 4 DSL Connection
[INFO][LAN] 08-04-2021 09:38:39 LAN sending RA to ff02::1
[EMERG][WAN] 08-04-2021 09:38:39 DSL link down.
[INFO][LAN] 08-04-2021 09:36:07 Successfully assign IP [192.168.2.101] to client mac [18:70:3b:37:19:d6], lease time [86400]
[INFO][LAN] 08-04-2021 09:36:07 unicasting packet to client yiaddr
[INFO][LAN] 08-04-2021 09:36:07 server_id = c0a80201
[INFO][LAN] 08-04-2021 09:36:07 Received REQUEST from client ip [0.0.0.0] mac [18:70:3b:37:19:d6]
[INFO][LAN] 08-04-2021 09:36:07 Received a packet
[INFO][LAN] 08-04-2021 09:36:07 Send OFFER of ip [192.168.2.101] to client mac [18:70:3b:37:19:d6]
[INFO][LAN] 08-04-2021 09:36:07 Find a lease info, and use the ip:6502a8c0
[INFO][LAN] 08-04-2021 09:36:07 No valid arp replies for this address
[INFO][LAN] 08-04-2021 09:36:06 LAN sending RA to ff02::1
[INFO][LAN] 08-04-2021 09:36:05 Received DISCOVER from client mac [18:70:3b:37:19:d6]
[INFO][LAN] 08-04-2021 09:36:05 Received a packet
[NOTICE][LAN] 08-04-2021 09:36:05 wl0: AP-STA-CONNECTED 18:70:3b:37:19:d6
[INFO][LAN] 08-04-2021 09:35:52 LAN sending RA to ff02::1
[INFO][LAN] 08-04-2021 09:35:48 LAN sending RA to ff02::1
[INFO][LAN] 08-04-2021 09:35:46 Successfully assign IP [192.168.2.104] to client mac [18:c0:4d:49:39:71], lease time [86400]
[INFO][LAN] 08-04-2021 09:35:46 unicasting packet to client yiaddr
[INFO][LAN] 08-04-2021 09:35:46 server_id = c0a80201
[INFO][LAN] 08-04-2021 09:35:46 Received REQUEST from client ip [0.0.0.0] mac [18:c0:4d:49:39:71]
[INFO][LAN] 08-04-2021 09:35:46 Received a packet
[INFO][LAN] 08-04-2021 09:35:46 Send OFFER of ip [192.168.2.104] to client mac [18:c0:4d:49:39:71]
[INFO][LAN] 08-04-2021 09:35:46 No valid arp replies for this address
[INFO][LAN] 08-04-2021 09:35:44 Received DISCOVER from client mac [18:c0:4d:49:39:71]
[INFO][LAN] 08-04-2021 09:35:44 Received a packet
[INFO][LAN] 08-04-2021 09:35:44 Transmit reply to fe80::40f8:8abf:61fd:6504%br0 on LAN
[INFO][LAN] 08-04-2021 09:35:44 Received information request from fe80::40f8:8abf:61fd:6504%br0 on LAN
[INFO][LAN] 08-04-2021 09:35:44 Transmit advertise to fe80::40f8:8abf:61fd:6504%br0 on LAN
[INFO][LAN] 08-04-2021 09:35:44 Received solicit from fe80::40f8:8abf:61fd:6504%br0 on LAN
[INFO][LAN] 08-04-2021 09:35:44 LAN sending RA to ff02::1
[INFO][LAN] 08-04-2021 09:35:44 broadcasting packet to client (NAK)
[WARNING][LAN] 08-04-2021 09:35:44 Send NAK to client ip [0.0.0.0] mac [18:c0:4d:49:39:71]
[INFO][LAN] 08-04-2021 09:35:44 Received REQUEST from client ip [0.0.0.0] mac [18:c0:4d:49:39:71]
[INFO][LAN] 08-04-2021 09:34:55 Successfully assign IP [192.168.2.103] to client mac [a2:9a:a4:57:dc:98], lease time [86400]
[INFO][LAN] 08-04-2021 09:34:55 unicasting packet to client yiaddr
[INFO][LAN] 08-04-2021 09:34:55 server_id = c0a80201
[INFO][LAN] 08-04-2021 09:34:55 Received REQUEST from client ip [0.0.0.0] mac [a2:9a:a4:57:dc:98]
[INFO][LAN] 08-04-2021 09:34:55 Received a packet
[INFO][LAN] 08-04-2021 09:34:54 unicasting packet to client yiaddr
[INFO][LAN] 08-04-2021 09:34:54 Send OFFER of ip [192.168.2.103] to client mac [a2:9a:a4:57:dc:98]
[INFO][LAN] 08-04-2021 09:34:54 Find a lease info, and use the ip:6702a8c0
[INFO][LAN] 08-04-2021 09:34:54 Received DISCOVER from client mac [a2:9a:a4:57:dc:98]
[INFO][LAN] 08-04-2021 09:34:54 Received a packet
[INFO][LAN] 08-04-2021 09:34:54 No valid arp replies for this address
[INFO][LAN] 08-04-2021 09:34:52 LAN sending RA to ff02::1
[INFO][LAN] 08-04-2021 09:34:52 Received DISCOVER from client mac [a2:9a:a4:57:dc:98]
[INFO][LAN] 08-04-2021 09:34:52 Received a packet
[NOTICE][LAN] 08-04-2021 09:34:52 wl0: AP-STA-CONNECTED a2:9a:a4:57:dc:98
[WARNING][Firewall] 08-04-2021 09:34:52 src=192.168.2.102 DST=5.62.38.41 PROTO=TCP SPT=59368 DPT=443 MARK=0x3 DROP
[EMERG][LAN] 08-04-2021 09:32:58 WIFI 2.4G Channel has been changed from channel 9 to 1.
[EMERG][LAN] 08-04-2021 09:32:58 WIFI 2.4G band width has been changed to 40M.
[INFO][Firewall] 08-04-2021 09:32:20 Firewall Detect has been disabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:32:20 Firewall Detect has been disabled on WAN VDSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:20 Firewall Detect has been disabled on WAN ADSL-DT.
[INFO][Firewall] 08-04-2021 09:32:20 Firewall Detect has been disabled on WAN ADSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:19 Firewall Detect has been disabled on WAN FTTH-IPTV.
[INFO][Firewall] 08-04-2021 09:32:19 Firewall Detect has been disabled on WAN FTTH-DATA.
[INFO][Firewall] 08-04-2021 09:32:19 Local Fragment Flood Detect has been disabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:32:19 Local Smurf Detect has been disabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:32:19 Local Winnuke Detect has been disabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:32:19 Forward TCP Scan Detect has been disabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:32:19 Local TCP Scan Detect has been disabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:32:19 Forward UDP Flood Detect has been disabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:32:19 Local ICMP Flood Detect has been disabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:32:19 Local UDP Flood Detect has been disabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:32:19 Local Fragment Flood Detect has been disabled on WAN VDSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:19 Local Smurf Detect has been disabled on WAN VDSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:19 Local Winnuke Detect has been disabled on WAN VDSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:19 Forward TCP Scan Detect has been disabled on WAN VDSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:19 Local TCP Scan Detect has been disabled on WAN VDSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:19 Forward UDP Flood Detect has been disabled on WAN VDSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:19 Local ICMP Flood Detect has been disabled on WAN VDSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:19 Local UDP Flood Detect has been disabled on WAN VDSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:18 Local Fragment Flood Detect has been disabled on WAN ADSL-DT.
[INFO][Firewall] 08-04-2021 09:32:18 Local Smurf Detect has been disabled on WAN ADSL-DT.
[INFO][Firewall] 08-04-2021 09:32:18 Local Winnuke Detect has been disabled on WAN ADSL-DT.
[INFO][Firewall] 08-04-2021 09:32:18 Forward TCP Scan Detect has been disabled on WAN ADSL-DT.
[INFO][Firewall] 08-04-2021 09:32:18 Local TCP Scan Detect has been disabled on WAN ADSL-DT.
[INFO][Firewall] 08-04-2021 09:32:18 Forward UDP Flood Detect has been disabled on WAN ADSL-DT.
[INFO][Firewall] 08-04-2021 09:32:18 Local ICMP Flood Detect has been disabled on WAN ADSL-DT.
[INFO][Firewall] 08-04-2021 09:32:18 Local UDP Flood Detect has been disabled on WAN ADSL-DT.
[INFO][Firewall] 08-04-2021 09:32:17 Local Fragment Flood Detect has been disabled on WAN ADSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:17 Local Smurf Detect has been disabled on WAN ADSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:17 Local Winnuke Detect has been disabled on WAN ADSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:17 Forward TCP Scan Detect has been disabled on WAN ADSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:17 Local TCP Scan Detect has been disabled on WAN ADSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:17 Forward UDP Flood Detect has been disabled on WAN ADSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:17 Local ICMP Flood Detect has been disabled on WAN ADSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:17 Local UDP Flood Detect has been disabled on WAN ADSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:17 Local Fragment Flood Detect has been disabled on WAN FTTH-IPTV.
[INFO][Firewall] 08-04-2021 09:32:17 Local Smurf Detect has been disabled on WAN FTTH-IPTV.
[INFO][Firewall] 08-04-2021 09:32:17 Local Winnuke Detect has been disabled on WAN FTTH-IPTV.
[INFO][Firewall] 08-04-2021 09:32:17 Forward TCP Scan Detect has been disabled on WAN FTTH-IPTV.
[INFO][Firewall] 08-04-2021 09:32:17 Local TCP Scan Detect has been disabled on WAN FTTH-IPTV.
[INFO][Firewall] 08-04-2021 09:32:17 Forward UDP Flood Detect has been disabled on WAN FTTH-IPTV.
[INFO][Firewall] 08-04-2021 09:32:17 Local ICMP Flood Detect has been disabled on WAN FTTH-IPTV.
[INFO][Firewall] 08-04-2021 09:32:17 Local UDP Flood Detect has been disabled on WAN FTTH-IPTV.
[INFO][Firewall] 08-04-2021 09:32:16 Local Fragment Flood Detect has been disabled on WAN FTTH-DATA.
[INFO][Firewall] 08-04-2021 09:32:16 Local Smurf Detect has been disabled on WAN FTTH-DATA.
[INFO][Firewall] 08-04-2021 09:32:16 Local Winnuke Detect has been disabled on WAN FTTH-DATA.
[INFO][Firewall] 08-04-2021 09:32:16 Forward TCP Scan Detect has been disabled on WAN FTTH-DATA.
[INFO][Firewall] 08-04-2021 09:32:16 Local TCP Scan Detect has been disabled on WAN FTTH-DATA.
[INFO][Firewall] 08-04-2021 09:32:16 Forward UDP Flood Detect has been disabled on WAN FTTH-DATA.
[INFO][Firewall] 08-04-2021 09:32:16 Local ICMP Flood Detect has been disabled on WAN FTTH-DATA.
[INFO][Firewall] 08-04-2021 09:32:16 Local UDP Flood Detect has been disabled on WAN FTTH-DATA.
[INFO][Firewall] 08-04-2021 09:32:15 Firewall Detect has been disabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:32:15 Firewall Detect has been disabled on WAN VDSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:15 Firewall Detect has been disabled on WAN ADSL-DT.
[INFO][Firewall] 08-04-2021 09:32:15 Firewall Detect has been disabled on WAN ADSL-DATA.
[INFO][Firewall] 08-04-2021 09:32:15 Firewall Detect has been disabled on WAN FTTH-IPTV.
[INFO][Firewall] 08-04-2021 09:32:15 Firewall Detect has been disabled on WAN FTTH-DATA.
[INFO][Firewall] 08-04-2021 09:32:14 Firewall DoS has been disabled on Lan.
[INFO][Firewall] 08-04-2021 09:32:14 Local Ping Response Block has been enabled.
[INFO][Firewall] 08-04-2021 09:32:14 Local Fragment Flood Detect has been disabled on LAN.
[INFO][Firewall] 08-04-2021 09:32:14 Local Smurf Detect has been disabled on LAN.
[INFO][Firewall] 08-04-2021 09:32:14 Local LAN Source Detect has been disabled.
[INFO][Firewall] 08-04-2021 09:32:14 Local Winnuke Detect has been disabled on LAN.
[INFO][Firewall] 08-04-2021 09:32:14 Local ICMP Flood Detect has been disabled on LAN.
[INFO][Firewall] 08-04-2021 09:32:14 Local UDP Flood Detect has been disabled on LAN.
[INFO][Firewall] 08-04-2021 09:32:14 UDP Bomb Detect has been disabled.
[INFO][Firewall] 08-04-2021 09:32:14 TCP Syn With Data Detect has been disabled.
[INFO][Firewall] 08-04-2021 09:32:14 IP Broadcast Source Detect has been disabled.
[INFO][Firewall] 08-04-2021 09:32:14 IP Land Detect has been disabled.
[INFO][Firewall] 08-04-2021 09:32:14 Port Scan Per IP Flood Detect has been disabled.
[INFO][Firewall] 08-04-2021 09:32:14 TCP FIN Per IP Flood Detect has been disabled.
[INFO][Firewall] 08-04-2021 09:32:14 TCP SYN Per IP Flood Detect has been disabled.
[INFO][Firewall] 08-04-2021 09:32:14 ICMP Per IP Flood Detect has been disabled.
[INFO][Firewall] 08-04-2021 09:32:14 UDP Per IP Flood Detect has been disabled.
[INFO][Firewall] 08-04-2021 09:32:14 IP Spoof Detect has been disabled.
[INFO][Firewall] 08-04-2021 09:32:14 Firewall Block Detect has been disabled.
[INFO][Firewall] 08-04-2021 09:32:14 Fireall Level has been disabled on Lan.
[INFO][System] 08-04-2021 09:31:07 No permission to get wifi_settings, access right: 0x0c.
[INFO][System] 08-04-2021 09:30:56 User 'vodafone' login successfully via HTTP from 192.168.2.102
[WARNING][System] 08-04-2021 09:30:37 User 'vodafone' login failed via HTTP from 192.168.2.102
[WARNING][System] 08-04-2021 09:30:35 User 'vodafone' login failed via HTTP from 192.168.2.102
[WARNING][System] 08-04-2021 09:30:29 User 'vodafone' login failed via HTTP from 192.168.2.102
[INFO][LAN] 08-04-2021 09:30:19 Successfully assign IP [192.168.2.102] to client mac [26:2b:b5:79:13:8f], lease time [86400]
[INFO][LAN] 08-04-2021 09:30:19 unicasting packet to client yiaddr
[INFO][LAN] 08-04-2021 09:30:19 server_id = c0a80201
[INFO][LAN] 08-04-2021 09:30:19 Received REQUEST from client ip [0.0.0.0] mac [26:2b:b5:79:13:8f]
[INFO][LAN] 08-04-2021 09:30:19 Received a packet
[INFO][LAN] 08-04-2021 09:30:18 unicasting packet to client yiaddr
[INFO][LAN] 08-04-2021 09:30:18 Send OFFER of ip [192.168.2.102] to client mac [26:2b:b5:79:13:8f]
[INFO][LAN] 08-04-2021 09:30:18 Find a lease info, and use the ip:6602a8c0
[INFO][LAN] 08-04-2021 09:30:18 Received DISCOVER from client mac [26:2b:b5:79:13:8f]
[INFO][LAN] 08-04-2021 09:30:18 Received a packet
[INFO][LAN] 08-04-2021 09:30:18 No valid arp replies for this address
[INFO][LAN] 08-04-2021 09:30:16 LAN sending RA to ff02::1
[INFO][LAN] 08-04-2021 09:30:16 Received DISCOVER from client mac [26:2b:b5:79:13:8f]
[INFO][LAN] 08-04-2021 09:30:16 Received a packet
[NOTICE][LAN] 08-04-2021 09:30:16 wl0: AP-STA-CONNECTED 26:2b:b5:79:13:8f
[INFO][LAN] 08-04-2021 09:30:06 LAN sending RA to ff02::1
[EMERG][LAN] 08-04-2021 09:30:01 WIFI 2.4G Channel has been changed from channel 1 to 9.
[NOTICE][LAN] 08-04-2021 09:30:00 ACSD: Timestamp(ms):1628069400 ACS-Trigger:INIT Selected Channel:#9 (0x1009)
[EMERG][LAN] 08-04-2021 09:30:00 WIFI 2.4G Channel has been changed from channel 8 to 1.
[EMERG][LAN] 08-04-2021 09:29:57 WIFI 5G Channel has been changed from channel 36 to 100.
[EMERG][LAN] 08-04-2021 09:29:57 WIFI 5G band width has been changed to 80M.
[NOTICE][LAN] 08-04-2021 09:29:56 ACSD: Timestamp(ms):1628069396 ACS-Trigger:INIT Selected Channel:#100/80 (0xe06a)
[INFO][LAN] 08-04-2021 09:29:50 LAN sending RA to ff02::1
[NOTICE][LAN] 08-04-2021 09:29:50 ACSD: acsd start...
[ERROR][LAN] 08-04-2021 09:29:50 Using interface wl0 with hwaddr 04:71:53:8a:ac:b1 and ssid "Vodafone-LMGS"
[NOTICE][LAN] 08-04-2021 09:29:50 wl0: interface state UNINITIALIZED->COUNTRY_UPDATE
[NOTICE][LAN] 08-04-2021 09:29:50 rfkill: Cannot open RFKILL control device
[ERROR][LAN] 08-04-2021 09:29:50 Configuration file: /tmp/wl0_hapd.conf
[INFO][LAN] 08-04-2021 09:29:49 LAN sending RA to ff02::1
[EMERG][LAN] 08-04-2021 09:29:49 WIFI 5G Channel has been changed from channel 100 to 36.
[EMERG][LAN] 08-04-2021 09:29:49 WIFI 5G band width has been changed to 20M.
[EMERG][LAN] 08-04-2021 09:29:47 WIFI 2.4G Channel has been changed from channel 1 to 8.
[INFO][LAN] 08-04-2021 09:29:47 LAN sending RA to ff02::1
[NOTICE][LAN] 08-04-2021 09:29:46 ACSD: Timestamp(ms):1628069386 ACS-Trigger:INIT Selected Channel:#8 (0x1008)
[EMERG][LAN] 08-04-2021 09:29:43 WIFI 5G Channel has been changed from channel 36 to 100.
[EMERG][LAN] 08-04-2021 09:29:43 WIFI 5G band width has been changed to 80M.
[NOTICE][LAN] 08-04-2021 09:29:42 ACSD: Timestamp(ms):1628069382 ACS-Trigger:INIT Selected Channel:#100/80 (0xe06a)
[INFO][LAN] 08-04-2021 09:29:36 LAN sending RA to ff02::1
[NOTICE][LAN] 08-04-2021 09:29:36 wl1: AP-ENABLED
[NOTICE][LAN] 08-04-2021 09:29:36 wl1: interface state COUNTRY_UPDATE->ENABLED
[ERROR][LAN] 08-04-2021 09:29:36 Using interface wl1 with hwaddr 04:71:53:8a:ac:b2 and ssid "Vodafone-LMGS"
[NOTICE][LAN] 08-04-2021 09:29:36 wl1: interface state UNINITIALIZED->COUNTRY_UPDATE
[NOTICE][LAN] 08-04-2021 09:29:36 ACSD: acsd start...
[NOTICE][LAN] 08-04-2021 09:29:36 rfkill: Cannot open RFKILL control device
[ERROR][LAN] 08-04-2021 09:29:36 Configuration file: /tmp/wl1_hapd.conf
[INFO][LAN] 08-04-2021 09:29:35 LAN sending RA to ff02::1
[EMERG][LAN] 08-04-2021 09:29:35 WIFI 2.4G Channel has been changed from channel 5 to 1.
[EMERG][LAN] 08-04-2021 09:29:35 WIFI 2.4G band width has been changed to 20M.
[INFO][LAN] 08-04-2021 09:29:33 LAN sending RA to ff02::1
[INFO][LAN] 08-04-2021 09:29:32 LAN sending RA to ff02::1
[NOTICE][LAN] 08-04-2021 09:29:32 nl80211: deinit ifname=wl1 disabled_11b_rates=0
[NOTICE][LAN] 08-04-2021 09:29:32 WPS UPnP: Advertisement sendto failed: 9 (Bad file descriptor)
[NOTICE][LAN] 08-04-2021 09:29:32 wl1: CTRL-EVENT-TERMINATING
[NOTICE][LAN] 08-04-2021 09:29:32 wl1: AP-DISABLED
[NOTICE][LAN] 08-04-2021 09:29:32 (null): interface state ENABLED->DISABLED
[NOTICE][LAN] 08-04-2021 09:29:32 wl0: AP-STA-DISCONNECTED 02:c8:ba:e4:96:ee
[NOTICE][LAN] 08-04-2021 09:29:32 wl0: AP-STA-DISCONNECTED 18:70:3b:37:19:d6
[NOTICE][LAN] 08-04-2021 09:28:41 wl0: AP-STA-CONNECTED 18:70:3b:37:19:d6
[NOTICE][LAN] 08-04-2021 09:28:40 wl1: AP-STA-DISCONNECTED 18:70:3b:37:19:d6
[INFO][LAN] 08-04-2021 09:28:24 Successfully assign IP [192.168.2.101] to client mac [18:70:3b:37:19:d6], lease time [86400]
[INFO][LAN] 08-04-2021 09:28:24 unicasting packet to client yiaddr
[INFO][LAN] 08-04-2021 09:28:24 server_id = c0a80201
[INFO][LAN] 08-04-2021 09:28:24 Received REQUEST from client ip [0.0.0.0] mac [18:70:3b:37:19:d6]
[INFO][LAN] 08-04-2021 09:28:24 Received a packet
[INFO][LAN] 08-04-2021 09:28:24 Send OFFER of ip [192.168.2.101] to client mac [18:70:3b:37:19:d6]
[INFO][LAN] 08-04-2021 09:28:24 No valid arp replies for this address
[INFO][LAN] 08-04-2021 09:28:22 LAN sending RA to ff02::1
[INFO][LAN] 08-04-2021 09:28:22 Received DISCOVER from client mac [18:70:3b:37:19:d6]
[INFO][LAN] 08-04-2021 09:28:22 Received a packet
[NOTICE][LAN] 08-04-2021 09:28:21 wl1: AP-STA-CONNECTED 18:70:3b:37:19:d6
[INFO][System] 08-04-2021 09:28:16 No permission to get wifi_settings, access right: 0x0c.
[INFO][System] 08-04-2021 09:27:32 User 'vodafone' login successfully via HTTP from 192.168.2.100
[WARNING][System] 08-04-2021 09:27:24 User 'vodafone' login failed via HTTP from 192.168.2.100
[INFO][System] 08-04-2021 09:27:12 Stopping HTTP redirect OK.
[INFO][DNS] 08-04-2021 09:27:12 DNSMasq proxy server disable redirect
[INFO][LAN] 08-04-2021 09:26:32 LAN sending RA to ff02::1
[INFO][LAN] 08-04-2021 09:26:16 LAN sending RA to ff02::1
[INFO][VoIP] 08-04-2021 09:26:06 Switch to primary proxy server arcor.de on line 0
[INFO][VoIP] 08-04-2021 09:26:04 VoIP service running at Aug 4 11:26:04 2021
[INFO][VoIP] 08-04-2021 09:26:04 VoIP call manager v02.01.00_01.10a.2021-04-27,20:04
[INFO][VoIP] 08-04-2021 09:26:04 Starting VoIP OK.
[INFO][VoIP] 08-04-2021 09:26:01 VoIP Starting ...
[INFO][System] 08-04-2021 09:26:01 Sync up with NTP Server successfully.
[INFO][LAN] 08-04-2021 09:26:00 LAN sending RA to ff02::1
[INFO][VoIP] 08-04-2021 09:26:00 Ringing schedule conf file is empty!
[INFO][VoIP] 08-04-2021 09:26:00 FXS_Number=*1
[INFO][VoIP] 08-04-2021 09:26:00 ReadGlobalSipConf ret=-2
[INFO][VoIP] 08-04-2021 09:26:00 Info Center Config Init...
[INFO][System] 08-04-2021 09:25:59 Sync up with NTP Server successfully.
[INFO][VoIP] 08-04-2021 09:25:58 Stopping VoIP OK.
[INFO][VoIP] 08-04-2021 09:25:56 VoIP service running at Aug 4 11:25:56 2021
[INFO][VoIP] 08-04-2021 09:25:56 VoIP call manager v02.01.00_01.10a.2021-04-27,20:04
[INFO][VoIP] 08-04-2021 09:25:56 Starting VoIP OK.
[INFO][VoIP] 08-04-2021 09:25:54 Send data/single wan update to VGW,wan id 10,ifName is ppp10,ipv4 address 178.6.254.207,ipv6 address ,default_wan_id 10,wan type 1
[INFO][VoIP] 08-04-2021 09:25:54 line 371 ,wan 10 start do data wan up
[INFO][VoIP] 08-04-2021 09:25:54 wanipv6 = ,size = 0
[INFO][VoIP] 08-04-2021 09:25:54 Voice binding wan_id is 10,default_wan_id is 10
[INFO][VoIP] 08-04-2021 09:25:54 Voice binding wan_id is 10,default_wan_id is 10,is_ipv6 = 0
[INFO][VoIP] 08-04-2021 09:25:54 wan 10 service_type = DATA,VOIP,MGNT,IPTV bud_voip_wan_id = 10
[INFO][VoIP] 08-04-2021 09:25:54 Interface wan_ip is 178.6.254.207, wan_ip_v6 ,is_ipv6 0 wan up id 10
[INFO][LAN] 08-04-2021 09:25:54 adapter hardware address 04:71:53:8a:ac:c0
[INFO][LAN] 08-04-2021 09:25:54 adapter index 19
[INFO][LAN] 08-04-2021 09:25:54 br1 (our ip) = 192.168.3.1
[INFO][LAN] 08-04-2021 09:25:54 Attaching option timezone to list
[INFO][LAN] 08-04-2021 09:25:54 Attaching option t2 to list
[INFO][LAN] 08-04-2021 09:25:54 Attaching option t1 to list
[INFO][LAN] 08-04-2021 09:25:54 Attaching option lease to list
[INFO][LAN] 08-04-2021 09:25:54 Attaching option dns to list
[INFO][LAN] 08-04-2021 09:25:54 Attaching option router to list
[INFO][LAN] 08-04-2021 09:25:54 Attaching option subnet to list
[INFO][LAN] 08-04-2021 09:25:54 error on select
[INFO][LAN] 08-04-2021 09:25:54 udhcp server receive signal 12
[INFO][LAN] 08-04-2021 09:25:54 adapter hardware address 04:71:53:8a:ac:b0
[INFO][LAN] 08-04-2021 09:25:54 adapter index 18
[INFO][LAN] 08-04-2021 09:25:54 br0 (our ip) = 192.168.2.1
[INFO][LAN] 08-04-2021 09:25:54 Attaching option dns to existing member of list
[INFO][LAN] 08-04-2021 09:25:54 Attaching option hostname to list
[INFO][LAN] 08-04-2021 09:25:54 Attaching option domain to list
[INFO][System] 08-04-2021 09:25:52 Starting MCPD OK.
[INFO][VoIP] 08-04-2021 09:25:52 VoIP Starting ...
[INFO][System] 08-04-2021 09:25:52 Stopping MCPD OK.
[INFO][VoIP] 08-04-2021 09:25:52 Ringing schedule conf file is empty!
[INFO][VoIP] 08-04-2021 09:25:52 FXS_Number=*1
[INFO][VoIP] 08-04-2021 09:25:52 ReadGlobalSipConf ret=-2
[INFO][VoIP] 08-04-2021 09:25:52 Info Center Config Init...
[INFO][UMTS] 08-04-2021 09:25:51 IPhone DNS Policy actived
[INFO][VoIP] 08-04-2021 09:25:51 line 364 start restart voip
[INFO][System] 08-04-2021 09:25:50 FSM---- Switch to Connect State.
[INFO][VoIP] 08-04-2021 09:25:49 276 start wan service Voice binding wan_id is 10
[INFO][VoIP] 08-04-2021 09:25:49 Voice binding wan_id is 10
[INFO][System] 08-04-2021 09:25:49 Starting NTP Client OK.
[INFO][System] 08-04-2021 09:25:49 Sync up with NTP Server failed.
[INFO][System] 08-04-2021 09:25:49 Stopping NTP Client OK.
[INFO][VoIP] 08-04-2021 09:25:49 Stopping VoIP OK.
[INFO][Firewall] 08-04-2021 09:25:48 PortMapping Rules have been flushed on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:48 DMZ Rules has been flushed on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:48 Static NAT Rules have been flushed on WAN VDSL-DT.
[INFO][System] 08-04-2021 09:25:48 Stopping HTTP redirect OK.
[INFO][DNS] 08-04-2021 09:25:48 DNSMasq proxy server disable redirect
[ERROR][DNS] 08-04-2021 09:25:48 failed to load names from /tmp/dnsmasq_hosts.d/data_hosts: No such file or directory
[INFO][DNS] 08-04-2021 09:25:48 Internet DNS Servers 176.95.16.250, 176.95.16.251.
[INFO][DNS] 08-04-2021 09:25:48 Internet DNS ready.
[WARNING][DNS] 08-04-2021 09:25:48 ignoring nameserver 127.0.0.1 - local interface
[WARNING][DNS] 08-04-2021 09:25:48 ignoring nameserver ::1 - local interface
[INFO][DNS] 08-04-2021 09:25:48 Starting DNSMasq proxy server OK.
[INFO][DNS] 08-04-2021 09:25:48 Stopping DNSMasq proxy OK.
[INFO][DNS] 08-04-2021 09:25:47 DNSMasq proxy server disable redirect
[INFO][UMTS] 08-04-2021 09:25:46 IPhone DNS Policy actived
[INFO][VoIP] 08-04-2021 09:25:46 Remove interface wan_id is 10,wan type 2.
[INFO][VoIP] 08-04-2021 09:25:46 VoIP WAN down, Voice trying to run in backup mode, try binding wan_id is 10
[INFO][VoIP] 08-04-2021 09:25:46 bud data ipv4 wan status 10,ipv6 wan status -1
[INFO][VoIP] 08-04-2021 09:25:46 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 10,is_ipv6 = 0,default_wan_id= 10
[INFO][VoIP] 08-04-2021 09:25:46 ===start stop voice wan
[INFO][System] 08-04-2021 09:25:46 Starting MCPD OK.
[INFO][System] 08-04-2021 09:25:45 Stopping MCPD OK.
[INFO][DNS] 08-04-2021 09:25:45 Internet DNS Servers 176.95.16.250, 176.95.16.251.
[INFO][DNS] 08-04-2021 09:25:45 Internet DNS ready.
[INFO][DNS] 08-04-2021 09:25:45 Internet DNS deactived.
[WARNING][WAN] 08-04-2021 09:25:44 WAN default route add to ppp10 gateway 84.59.211.1.
[INFO][WAN] 08-04-2021 09:25:44 Data WAN11 Activated!
[INFO][WAN] 08-04-2021 09:25:44 bud update WAN11 status to 2.
[WARNING][WAN] 08-04-2021 09:25:44 WAN VDSL-DT is up, mode is PPPoE, IP is 178.6.254.207.
[WARNING][WAN] 08-04-2021 09:25:44 WAN VDSL-DT is down.
[INFO][LAN] 08-04-2021 09:25:44 LAN sending RA to ff02::1
[INFO][WAN] 08-04-2021 09:25:44 PPP CHAP MD5 authentication is successful on WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:25:44 PPPOE PADS has been received from WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:25:44 PPPOE PADR has been sent from WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:25:44 PPPOE PADO has been received from WAN VDSL-DT, BRAS name is LUHCOS00101.
[INFO][WAN] 08-04-2021 09:25:44 PPPOE PADI has been sent from WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:25:44 PPPOE PADT has been sent from WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:25:43 Start WAN 10 IP Connection
[INFO][WAN] 08-04-2021 09:25:43 WAN VDSL-DT has been started, PHY link up
[INFO][VoIP] 08-04-2021 09:25:43 Send data/single wan update to VGW,wan id 10,ifName is ppp10,ipv4 address 178.6.254.243,ipv6 address ,default_wan_id 10,wan type 1
[INFO][VoIP] 08-04-2021 09:25:43 line 371 ,wan 10 start do data wan up
[INFO][VoIP] 08-04-2021 09:25:43 wanipv6 = ,size = 0
[INFO][VoIP] 08-04-2021 09:25:43 Voice binding wan_id is 10,default_wan_id is 10
[INFO][VoIP] 08-04-2021 09:25:43 Voice binding wan_id is 10,default_wan_id is 10,is_ipv6 = 0
[INFO][VoIP] 08-04-2021 09:25:43 wan 10 service_type = DATA,VOIP,MGNT,IPTV bud_voip_wan_id = 10
[INFO][VoIP] 08-04-2021 09:25:43 ignore useless wan down
[INFO][VoIP] 08-04-2021 09:25:43 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 11,is_ipv6 = 0,default_wan_id= 10
[INFO][VoIP] 08-04-2021 09:25:43 Interface wan_ip is 178.6.254.243, wan_ip_v6 ,is_ipv6 0 wan up id 10
[INFO][VoIP] 08-04-2021 09:25:43 ===start stop voice wan
[WARNING][System] 08-04-2021 09:25:43 HTTPD---- bind to socket fail:99.
[INFO][VoIP] 08-04-2021 09:25:43 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 11,is_ipv6 = 1,default_wan_id= 10
[INFO][LAN] 08-04-2021 09:25:43 adapter hardware address 04:71:53:8a:ac:c0
[INFO][LAN] 08-04-2021 09:25:43 adapter index 19
[INFO][LAN] 08-04-2021 09:25:43 br1 (our ip) = 192.168.3.1
[INFO][LAN] 08-04-2021 09:25:43 Attaching option timezone to list
[INFO][LAN] 08-04-2021 09:25:43 Attaching option t2 to list
[INFO][LAN] 08-04-2021 09:25:43 Attaching option t1 to list
[INFO][LAN] 08-04-2021 09:25:43 Attaching option lease to list
[INFO][LAN] 08-04-2021 09:25:43 Attaching option dns to list
[INFO][LAN] 08-04-2021 09:25:43 Attaching option router to list
[INFO][LAN] 08-04-2021 09:25:43 Attaching option subnet to list
[INFO][LAN] 08-04-2021 09:25:43 error on select
[INFO][LAN] 08-04-2021 09:25:43 udhcp server receive signal 12
[INFO][LAN] 08-04-2021 09:25:43 adapter hardware address 04:71:53:8a:ac:b0
[INFO][LAN] 08-04-2021 09:25:43 adapter index 18
[INFO][LAN] 08-04-2021 09:25:43 br0 (our ip) = 192.168.2.1
[INFO][LAN] 08-04-2021 09:25:43 Attaching option dns to existing member of list
[INFO][LAN] 08-04-2021 09:25:43 Attaching option hostname to list
[INFO][LAN] 08-04-2021 09:25:43 Attaching option domain to list
[INFO][WAN] 08-04-2021 09:25:42 Stop WAN 11 IP Connection
[INFO][WAN] 08-04-2021 09:25:42 Start WAN 10 DSL Connection
[INFO][WAN] 08-04-2021 09:25:42 bud update WAN11 status to 0.
[INFO][WAN] 08-04-2021 09:25:41 Stop WAN 10 DSL Connection
[INFO][LAN] 08-04-2021 09:25:41 LAN sending RA to ff02::1
[INFO][System] 08-04-2021 09:25:41 Starting HTTP redirect OK.
[INFO][DNS] 08-04-2021 09:25:41 DNSMasq proxy server enable redirect
[INFO][VoIP] 08-04-2021 09:25:41 276 start wan service Voice binding wan_id is 10
[INFO][VoIP] 08-04-2021 09:25:41 Voice binding wan_id is 10
[INFO][System] 08-04-2021 09:25:41 Stopping NTP Client OK.
[INFO][Firewall] 08-04-2021 09:25:40 PortMapping Rules have been flushed on WAN VDSL-DT.
[INFO][VoIP] 08-04-2021 09:25:40 VoIP WAN down, no available connection
[INFO][VoIP] 08-04-2021 09:25:40 Remove interface wan_id is 10,wan type 1.
[INFO][VoIP] 08-04-2021 09:25:40 bud data ipv4 wan status -1,ipv6 wan status -1
[INFO][VoIP] 08-04-2021 09:25:40 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 10,is_ipv6 = 0,default_wan_id= 10
[INFO][VoIP] 08-04-2021 09:25:40 ===start stop voice wan
[INFO][Firewall] 08-04-2021 09:25:40 DMZ Rules has been flushed on WAN VDSL-DT.
[INFO][DNS] 08-04-2021 09:25:40 Internet DNS deactived.
[INFO][WAN] 08-04-2021 09:25:40 PPPOE PADT has been sent from WAN VDSL-DT
[INFO][LAN] 08-04-2021 09:25:40 LAN sending RA to ff02::1
[INFO][Firewall] 08-04-2021 09:25:40 Static NAT Rules have been flushed on WAN VDSL-DT.
[INFO][System] 08-04-2021 09:25:40 FSM---- Switch to Connect State.
[INFO][System] 08-04-2021 09:25:40 Stopping HTTP redirect OK.
[INFO][DNS] 08-04-2021 09:25:40 DNSMasq proxy server disable redirect
[INFO][System] 08-04-2021 09:25:40 Starting HTTP redirect OK.
[INFO][DNS] 08-04-2021 09:25:40 DNSMasq proxy server enable redirect
[ERROR][DNS] 08-04-2021 09:25:40 failed to load names from /tmp/dnsmasq_hosts.d/data_hosts: No such file or directory
[WARNING][DNS] 08-04-2021 09:25:40 ignoring nameserver 127.0.0.1 - local interface
[WARNING][DNS] 08-04-2021 09:25:40 ignoring nameserver ::1 - local interface
[INFO][DNS] 08-04-2021 09:25:40 Starting DNSMasq proxy server OK.
[INFO][DNS] 08-04-2021 09:25:40 Stopping DNSMasq proxy OK.
[INFO][VoIP] 08-04-2021 09:25:39 VoIP WAN down, no available connection
[INFO][VoIP] 08-04-2021 09:25:39 Remove interface wan_id is 10,wan type 1.
[INFO][VoIP] 08-04-2021 09:25:39 bud data ipv4 wan status -1,ipv6 wan status -1
[INFO][VoIP] 08-04-2021 09:25:39 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 10,is_ipv6 = 0,default_wan_id= 10
[INFO][VoIP] 08-04-2021 09:25:39 ===start stop voice wan
[INFO][DNS] 08-04-2021 09:25:39 Internet DNS deactived.
[INFO][System] 08-04-2021 09:25:39 Starting HTTP redirect OK.
[INFO][DNS] 08-04-2021 09:25:39 DNSMasq proxy server enable redirect
[INFO][VoIP] 08-04-2021 09:25:39 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 10,is_ipv6 = 1,default_wan_id= 10
[INFO][DNS] 08-04-2021 09:25:39 DNSMasq proxy server disable redirect
[INFO][DNS] 08-04-2021 09:25:38 Internet DNS deactived.
[INFO][WAN] 08-04-2021 09:25:38 Stop WAN 10 IP Connection
[INFO][WAN] 08-04-2021 09:25:38 bud update WAN11 V6 status to 0.
[INFO][WAN] 08-04-2021 09:25:38 IPTV WAN11 DeActivated!
[INFO][WAN] 08-04-2021 09:25:38 bud update WAN11 status to 0.
[INFO][UMTS] 08-04-2021 09:25:38 IPhone DNS Policy actived
[INFO][VoIP] 08-04-2021 09:25:37 Remove interface wan_id is 10,wan type 2.
[INFO][VoIP] 08-04-2021 09:25:37 VoIP WAN down, Voice trying to run in backup mode, try binding wan_id is 10
[INFO][VoIP] 08-04-2021 09:25:37 bud data ipv4 wan status 10,ipv6 wan status -1
[INFO][VoIP] 08-04-2021 09:25:37 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 10,is_ipv6 = 0,default_wan_id= 10
[INFO][VoIP] 08-04-2021 09:25:37 ===start stop voice wan
[INFO][VoIP] 08-04-2021 09:25:37 ignore useless wan down
[INFO][VoIP] 08-04-2021 09:25:37 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 9,is_ipv6 = 0,default_wan_id= 10
[INFO][System] 08-04-2021 09:25:37 Starting MCPD OK.
[INFO][System] 08-04-2021 09:25:37 Stopping MCPD OK.
[INFO][VoIP] 08-04-2021 09:25:36 ignore useless wan down
[INFO][VoIP] 08-04-2021 09:25:36 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 9,is_ipv6 = 1,default_wan_id= 10
[INFO][VoIP] 08-04-2021 09:25:36 ===start stop voice wan
[INFO][WAN] 08-04-2021 09:25:36 Stop WAN 9 IP Connection
[INFO][WAN] 08-04-2021 09:25:36 Start WAN 8 DSL Connection
[INFO][WAN] 08-04-2021 09:25:35 bud update WAN9 status to 0.
[INFO][DNS] 08-04-2021 09:25:35 Internet DNS Servers 176.95.16.250, 176.95.16.251.
[INFO][DNS] 08-04-2021 09:25:35 Internet DNS ready.
[INFO][DNS] 08-04-2021 09:25:35 Internet DNS deactived.
[WARNING][WAN] 08-04-2021 09:25:34 WAN default route add to ppp10 gateway 84.59.211.1.
[INFO][System] 08-04-2021 09:25:34 FSM---- Switch to Connect State.
[INFO][WAN] 08-04-2021 09:25:34 Data WAN11 Activated!
[INFO][WAN] 08-04-2021 09:25:34 bud update WAN11 status to 2.
[WARNING][WAN] 08-04-2021 09:25:34 WAN VDSL-DT is up, mode is PPPoE, IP is 178.6.254.243.
[WARNING][WAN] 08-04-2021 09:25:34 WAN VDSL-DT is down.
[INFO][LAN] 08-04-2021 09:25:34 LAN sending RA to ff02::1
[INFO][WAN] 08-04-2021 09:25:34 PPP CHAP MD5 authentication is successful on WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:25:34 PPPOE PADS has been received from WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:25:34 PPPOE PADR has been sent from WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:25:34 PPPOE PADO has been received from WAN VDSL-DT, BRAS name is LUHCOS00101.
[INFO][WAN] 08-04-2021 09:25:34 PPPOE PADI has been sent from WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:25:34 PPPOE PADT has been sent from WAN VDSL-DT
[INFO][LAN] 08-04-2021 09:25:33 LAN sending RA to ff02::1
[INFO][WAN] 08-04-2021 09:25:33 Start WAN 10 IP Connection
[INFO][WAN] 08-04-2021 09:25:33 WAN VDSL-DT has been started, PHY link up
[INFO][WAN] 08-04-2021 09:25:33 Stop WAN 8 DSL Connection
[INFO][WAN] 08-04-2021 09:25:33 bud update WAN9 V6 status to 0.
[INFO][WAN] 08-04-2021 09:25:33 bud update WAN9 status to 0.
[INFO][WAN] 08-04-2021 09:25:32 Start WAN 10 DSL Connection
[INFO][WAN] 08-04-2021 09:25:32 bud update WAN11 status to 0.
[INFO][WAN] 08-04-2021 09:25:31 Stop WAN 10 DSL Connection
[INFO][LAN] 08-04-2021 09:25:31 LAN sending RA to ff02::1
[INFO][System] 08-04-2021 09:25:31 Starting HTTP redirect OK.
[INFO][DNS] 08-04-2021 09:25:31 DNSMasq proxy server enable redirect
[INFO][VoIP] 08-04-2021 09:25:30 VoIP WAN down, no available connection
[INFO][VoIP] 08-04-2021 09:25:30 Remove interface wan_id is 10,wan type 1.
[INFO][VoIP] 08-04-2021 09:25:30 bud data ipv4 wan status -1,ipv6 wan status -1
[INFO][VoIP] 08-04-2021 09:25:30 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 10,is_ipv6 = 0,default_wan_id= 10
[INFO][VoIP] 08-04-2021 09:25:30 ===start stop voice wan
[INFO][DNS] 08-04-2021 09:25:30 Internet DNS deactived.
[INFO][WAN] 08-04-2021 09:25:30 PPPOE PADT has been sent from WAN VDSL-DT
[INFO][LAN] 08-04-2021 09:25:30 LAN sending RA to ff02::1
[INFO][System] 08-04-2021 09:25:30 Starting HTTP redirect OK.
[INFO][DNS] 08-04-2021 09:25:30 DNSMasq proxy server enable redirect
[INFO][System] 08-04-2021 09:25:29 FSM---- Switch to Connect State.
[INFO][VoIP] 08-04-2021 09:25:29 VoIP WAN down, no available connection
[INFO][VoIP] 08-04-2021 09:25:29 Remove interface wan_id is 10,wan type 1.
[INFO][VoIP] 08-04-2021 09:25:29 bud data ipv4 wan status -1,ipv6 wan status -1
[INFO][VoIP] 08-04-2021 09:25:29 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 10,is_ipv6 = 0,default_wan_id= 10
[INFO][VoIP] 08-04-2021 09:25:29 ===start stop voice wan
[INFO][DNS] 08-04-2021 09:25:29 Internet DNS deactived.
[INFO][System] 08-04-2021 09:25:29 Starting HTTP redirect OK.
[INFO][DNS] 08-04-2021 09:25:29 DNSMasq proxy server enable redirect
[INFO][System] 08-04-2021 09:25:28 Stopping NTP Client OK.
[INFO][VoIP] 08-04-2021 09:25:28 VoIP WAN down, no available connection
[INFO][VoIP] 08-04-2021 09:25:28 Remove interface wan_id is 10,wan type 1.
[INFO][VoIP] 08-04-2021 09:25:28 bud data ipv4 wan status -1,ipv6 wan status -1
[INFO][VoIP] 08-04-2021 09:25:28 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 10,is_ipv6 = 1,default_wan_id= 10
[INFO][VoIP] 08-04-2021 09:25:28 ===start stop voice wan
[INFO][DNS] 08-04-2021 09:25:28 Internet DNS deactived.
[INFO][WAN] 08-04-2021 09:25:28 Stop WAN 10 IP Connection
[INFO][WAN] 08-04-2021 09:25:28 bud update WAN11 V6 status to 0.
[INFO][WAN] 08-04-2021 09:25:28 IPTV WAN11 DeActivated!
[INFO][WAN] 08-04-2021 09:25:28 bud update WAN11 status to 0.
[ERROR][System] 08-04-2021 09:25:27 TR069 connects to ACS server failed, http error 503.
[INFO][Firewall] 08-04-2021 09:25:25 Local Fragment Flood detect has been enabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:25 Local Smurf Detect has been enabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:25 Local Winnuke Detect has been enabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:25 Local TCP FIN Flood Detect has been enabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:25 Local TCP SYN Flood Detect has been enabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:25 Local ICMP Flood Detect has been enabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:25 Forward UDP Flood Detect has been enabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:25 Local UDP Flood Detect has been enabled on WAN VDSL-DT.
[INFO][System] 08-04-2021 09:25:24 FSM---- Switch to Connect State.
[INFO][Firewall] 08-04-2021 09:25:23 Local Fragment Flood Detect has been disabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:23 Local Smurf Detect has been disabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:23 Local Winnuke Detect has been disabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:23 Forward TCP Scan Detect has been disabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:23 Local TCP Scan Detect has been disabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:23 Forward UDP Flood Detect has been disabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:23 Local ICMP Flood Detect has been disabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:23 Local UDP Flood Detect has been disabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:23 IP Filter Rules have been flushed on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:23 PortMapping Rules have been flushed on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:23 PortTrigger Rules have been flushed on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:23 DMZ Rules has been flushed on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:25:23 Static NAT Rules have been flushed on WAN VDSL-DT.
[INFO][System] 08-04-2021 09:25:22 Stopping HTTP redirect OK.
[INFO][DNS] 08-04-2021 09:25:22 DNSMasq proxy server disable redirect
[INFO][System] 08-04-2021 09:25:20 FSM---- Switch to Connect State.
[INFO][System] 08-04-2021 09:25:20 CWMP Connection Request is Active.
[INFO][System] 08-04-2021 09:25:20 Receive Configuration from ACS Server
[INFO][System] 08-04-2021 09:25:13 FSM---- Switch to Connect State.
[INFO][System] 08-04-2021 09:25:13 TR069 got connection request file from ACS server.
[INFO][System] 08-04-2021 09:25:13 CWMP Connection Request is Active.
[INFO][System] 08-04-2021 09:25:13 Connection request from 145.253.3.236 success
[INFO][System] 08-04-2021 09:25:13 Receive Configuration from ACS Server
[INFO][System] 08-04-2021 09:25:08 FSM---- Switch to Connect State.
[INFO][LAN] 08-04-2021 09:23:44 Successfully assign IP [192.168.2.100] to client mac [02:c8:ba:e4:96:ee], lease time [86400]
[INFO][LAN] 08-04-2021 09:23:44 unicasting packet to client yiaddr
[INFO][LAN] 08-04-2021 09:23:44 server_id = c0a80201
[INFO][LAN] 08-04-2021 09:23:44 Received REQUEST from client ip [0.0.0.0] mac [02:c8:ba:e4:96:ee]
[INFO][LAN] 08-04-2021 09:23:44 Received a packet
[INFO][LAN] 08-04-2021 09:23:43 unicasting packet to client yiaddr
[INFO][LAN] 08-04-2021 09:23:43 Send OFFER of ip [192.168.2.100] to client mac [02:c8:ba:e4:96:ee]
[INFO][LAN] 08-04-2021 09:23:43 Find a lease info, and use the ip:6402a8c0
[INFO][LAN] 08-04-2021 09:23:43 Received DISCOVER from client mac [02:c8:ba:e4:96:ee]
[INFO][LAN] 08-04-2021 09:23:43 Received a packet
[INFO][LAN] 08-04-2021 09:23:43 No valid arp replies for this address
[INFO][LAN] 08-04-2021 09:23:42 LAN sending RA to ff02::1
[INFO][LAN] 08-04-2021 09:23:41 Received DISCOVER from client mac [02:c8:ba:e4:96:ee]
[INFO][LAN] 08-04-2021 09:23:41 Received a packet
[NOTICE][LAN] 08-04-2021 09:23:41 wl0: AP-STA-CONNECTED 02:c8:ba:e4:96:ee
[INFO][LAN] 08-04-2021 09:23:38 LAN sending RA to ff02::1
[INFO][LAN] 08-04-2021 09:23:22 LAN sending RA to ff02::1
[INFO][System] 08-04-2021 09:23:21 Sync up with NTP Server successfully.
[INFO][System] 08-04-2021 09:23:18 Sync up with NTP Server successfully.
[INFO][VoIP] 08-04-2021 09:23:10 Send data/single wan update to VGW,wan id 10,ifName is ppp10,ipv4 address 88.69.65.57,ipv6 address ,default_wan_id 10,wan type 1
[INFO][VoIP] 08-04-2021 09:23:10 line 371 ,wan 10 start do data wan up
[INFO][VoIP] 08-04-2021 09:23:10 wanipv6 = ,size = 0
[INFO][VoIP] 08-04-2021 09:23:10 Voice binding wan_id is 10,default_wan_id is 10
[INFO][VoIP] 08-04-2021 09:23:10 Voice binding wan_id is 10,default_wan_id is 10,is_ipv6 = 0
[INFO][VoIP] 08-04-2021 09:23:10 wan 10 service_type = DATA,VOIP,MGNT,IPTV bud_voip_wan_id = 10
[INFO][VoIP] 08-04-2021 09:23:10 Interface wan_ip is 88.69.65.57, wan_ip_v6 ,is_ipv6 0 wan up id 10
[INFO][LAN] 08-04-2021 09:23:10 adapter hardware address 04:71:53:8a:ac:b0
[INFO][LAN] 08-04-2021 09:23:10 adapter index 18
[INFO][LAN] 08-04-2021 09:23:10 br0 (our ip) = 192.168.2.1
[INFO][LAN] 08-04-2021 09:23:10 Attaching option timezone to list
[INFO][LAN] 08-04-2021 09:23:10 Attaching option t2 to list
[INFO][LAN] 08-04-2021 09:23:10 Attaching option t1 to list
[INFO][LAN] 08-04-2021 09:23:10 Attaching option lease to list
[INFO][LAN] 08-04-2021 09:23:10 Attaching option dns to existing member of list
[INFO][LAN] 08-04-2021 09:23:10 Attaching option dns to list
[INFO][LAN] 08-04-2021 09:23:10 Attaching option router to list
[INFO][LAN] 08-04-2021 09:23:10 Attaching option subnet to list
[INFO][LAN] 08-04-2021 09:23:10 adapter hardware address 04:71:53:8a:ac:c0
[INFO][LAN] 08-04-2021 09:23:10 adapter index 19
[INFO][LAN] 08-04-2021 09:23:10 br1 (our ip) = 192.168.3.1
[INFO][LAN] 08-04-2021 09:23:10 error on select
[INFO][LAN] 08-04-2021 09:23:10 udhcp server receive signal 12
[INFO][LAN] 08-04-2021 09:23:10 Attaching option hostname to list
[INFO][LAN] 08-04-2021 09:23:10 Attaching option domain to list
[INFO][System] 08-04-2021 09:23:09 Starting MCPD OK.
[INFO][System] 08-04-2021 09:23:09 Stopping MCPD OK.
[INFO][UMTS] 08-04-2021 09:23:08 IPhone DNS Policy actived
[INFO][VoIP] 08-04-2021 09:23:08 276 start wan service Voice binding wan_id is 10
[INFO][VoIP] 08-04-2021 09:23:08 Voice binding wan_id is 10
[INFO][System] 08-04-2021 09:23:08 Starting NTP Client OK.
[INFO][System] 08-04-2021 09:23:08 Sync up with NTP Server failed.
[INFO][System] 08-04-2021 09:23:08 Stopping NTP Client OK.
[INFO][Firewall] 08-04-2021 09:23:08 PortMapping Rules have been flushed on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:23:08 DMZ Rules has been flushed on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:23:08 Static NAT Rules have been flushed on WAN VDSL-DT.
[INFO][DNS] 08-04-2021 09:23:07 Internet DNS Servers 176.95.16.250, 176.95.16.251.
[INFO][DNS] 08-04-2021 09:23:07 Internet DNS ready.
[WARNING][DNS] 08-04-2021 09:23:07 ignoring nameserver 127.0.0.1 - local interface
[WARNING][DNS] 08-04-2021 09:23:07 ignoring nameserver ::1 - local interface
[INFO][DNS] 08-04-2021 09:23:07 Starting DNSMasq proxy server OK.
[INFO][DNS] 08-04-2021 09:23:07 Stopping DNSMasq proxy OK.
[INFO][LAN] 08-04-2021 09:23:06 LAN sending RA to ff02::1
[INFO][DNS] 08-04-2021 09:23:06 DNSMasq proxy server disable redirect
[INFO][System] 08-04-2021 09:23:06 Starting HTTP redirect OK.
[INFO][DNS] 08-04-2021 09:23:05 DNSMasq proxy server enable redirect
[INFO][VoIP] 08-04-2021 09:23:05 ignore useless wan down
[INFO][VoIP] 08-04-2021 09:23:05 Voice binding wan_id is -1,binding_1 wan_id = 10,stop wan_id is 8,is_ipv6 = 0,default_wan_id= 10
[INFO][VoIP] 08-04-2021 09:23:05 can not get bind voice wan
[INFO][VoIP] 08-04-2021 09:23:05 ===start stop voice wan
[INFO][UMTS] 08-04-2021 09:23:05 IPhone DNS Policy actived
[INFO][VoIP] 08-04-2021 09:23:05 Voice binding wan_id is -1,binding_1 wan_id = 10,stop wan_id is 8,is_ipv6 = 1,default_wan_id= 10
[INFO][VoIP] 08-04-2021 09:23:05 Remove interface wan_id is 10,wan type 2.
[INFO][VoIP] 08-04-2021 09:23:05 Voice binding wan_id is -1,binding_1 wan_id = 10,stop wan_id is 10,is_ipv6 = 0,default_wan_id= 10
[INFO][System] 08-04-2021 09:23:05 Starting MCPD OK.
[INFO][WAN] 08-04-2021 09:23:05 Stop WAN 8 IP Connection
[INFO][System] 08-04-2021 09:23:05 Stopping MCPD OK.
[INFO][DNS] 08-04-2021 09:23:04 Internet DNS Servers 176.95.16.250, 176.95.16.251.
[INFO][DNS] 08-04-2021 09:23:04 Internet DNS ready.
[INFO][DNS] 08-04-2021 09:23:04 Internet DNS deactived.
[INFO][DNS] 08-04-2021 09:23:04 Stopping UPnP OK.
[WARNING][WAN] 08-04-2021 09:23:04 WAN default route add to ppp10 gateway 88.69.64.1.
[INFO][WAN] 08-04-2021 09:23:04 Data WAN11 Activated!
[INFO][WAN] 08-04-2021 09:23:04 bud update WAN11 status to 2.
[WARNING][WAN] 08-04-2021 09:23:03 WAN VDSL-DT is up, mode is PPPoE, IP is 88.69.65.57.
[WARNING][WAN] 08-04-2021 09:23:02 WAN VDSL-DT is down.
[INFO][LAN] 08-04-2021 09:23:02 LAN sending RA to ff02::1
[INFO][WAN] 08-04-2021 09:23:02 PPP CHAP MD5 authentication is successful on WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:23:02 PPPOE PADS has been received from WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:23:02 PPPOE PADR has been sent from WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:23:02 PPPOE PADO has been received from WAN VDSL-DT, BRAS name is LUHCOS00101.
[INFO][WAN] 08-04-2021 09:23:02 PPPOE PADI has been sent from WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:23:02 PPPOE PADI has been sent from WAN VDSL-DATA
[INFO][WAN] 08-04-2021 09:22:45 PPPOE PADI has been sent from WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:22:45 PPPOE PADI has been sent from WAN VDSL-DATA
[EMERG][WAN] 08-04-2021 09:22:34 DSL link up.
[EMERG][WAN] 08-04-2021 09:22:33 DSL link up.
[EMERG][WAN] 08-04-2021 09:22:32 DSL link up.
[EMERG][WAN] 08-04-2021 09:22:30 DSL link up.
[EMERG][WAN] 08-04-2021 09:22:29 DSL link up.
[EMERG][WAN] 08-04-2021 09:22:28 DSL link up.
[EMERG][WAN] 08-04-2021 09:22:26 DSL link up.
[EMERG][WAN] 08-04-2021 09:22:25 DSL link up.
[INFO][LAN] 08-04-2021 09:22:24 LAN sending RA to ff02::1
[EMERG][WAN] 08-04-2021 09:22:24 DSL link up.
[EMERG][WAN] 08-04-2021 09:22:22 DSL link up.
[EMERG][WAN] 08-04-2021 09:22:21 DSL link up.
[EMERG][WAN] 08-04-2021 09:22:20 DSL link up.
[EMERG][WAN] 08-04-2021 09:22:18 DSL link up.
[EMERG][WAN] 08-04-2021 09:22:17 DSL link up.
[EMERG][WAN] 08-04-2021 09:22:16 DSL link up.
[EMERG][WAN] 08-04-2021 09:22:14 DSL link up.
[INFO][LAN] 08-04-2021 09:22:08 LAN sending RA to ff02::1
[INFO][LAN] 08-04-2021 09:21:52 LAN sending RA to ff02::1
[INFO][WAN] 08-04-2021 09:21:49 PPPOE PADI has been sent from WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:21:49 PPPOE PADI has been sent from WAN VDSL-DATA
[EMERG][LAN] 08-04-2021 09:21:38 WIFI 2.4G Channel has been changed from channel 1 to 5.
[EMERG][LAN] 08-04-2021 09:21:38 WIFI 2.4G band width has been changed to 20/40M auto.
[NOTICE][LAN] 08-04-2021 09:21:37 ACSD: Timestamp(ms):1619555809 ACS-Trigger:INIT Selected Channel:#5u (0x1903)
[INFO][LAN] 08-04-2021 09:21:36 LAN sending RA to ff02::1
[INFO][WAN] 08-04-2021 09:21:36 PPPOE PADI has been sent from WAN VDSL-DATA
[INFO][WAN] 08-04-2021 09:21:36 PPPOE PADI has been sent from WAN VDSL-DT
[INFO][WAN] 08-04-2021 09:21:35 Start WAN 10 IP Connection
[INFO][WAN] 08-04-2021 09:21:35 Start WAN 8 IP Connection
[INFO][WAN] 08-04-2021 09:21:35 WAN VDSL-DT has been started, PHY link up
[INFO][WAN] 08-04-2021 09:21:35 WAN VDSL-DATA has been started, PHY link up
[INFO][LAN] 08-04-2021 09:21:35 LAN sending RA to ff02::1
[INFO][LAN] 08-04-2021 09:21:34 LAN sending RA to ff02::1
[INFO][WAN] 08-04-2021 09:21:34 Starting VDSL interface OK.
[INFO][WAN] 08-04-2021 09:21:34 Start WAN 8 DSL Connection
[INFO][WAN] 08-04-2021 09:21:34 Start WAN 10 DSL Connection
[INFO][WAN] 08-04-2021 09:21:34 Start WAN 4 DSL Connection
[INFO][LAN] 08-04-2021 09:21:33 LAN sending RA to ff02::1
[EMERG][LAN] 08-04-2021 09:21:33 WIFI 5G Channel has been changed from channel 36 to 100.
[EMERG][LAN] 08-04-2021 09:21:33 WIFI 5G band width has been changed to 80M.
[EMERG][WAN] 08-04-2021 09:21:33 DSL link up.
[NOTICE][LAN] 08-04-2021 09:21:32 ACSD: Timestamp(ms):1619555805 ACS-Trigger:INIT Selected Channel:#100/80 (0xe06a)
[INFO][VoIP] 08-04-2021 09:21:29 VoIP service running at Apr 27 20:36:41 2021
[INFO][VoIP] 08-04-2021 09:21:29 VoIP call manager v02.01.00_01.10a.2021-04-27,20:04
[INFO][VoIP] 08-04-2021 09:21:29 Starting VoIP OK.
[INFO][System] 08-04-2021 09:21:27 Add BOOTSTRAP due to first-time CPE installation.
[NOTICE][LAN] 08-04-2021 09:21:26 ACSD: acsd start...
[INFO][VoIP] 08-04-2021 09:21:25 VoIP Starting ...
[INFO][VoIP] 08-04-2021 09:21:24 Ringing schedule conf file is empty!
[INFO][VoIP] 08-04-2021 09:21:24 FXS_Number=*1
[NOTICE][LAN] 08-04-2021 09:21:24 wl1: AP-ENABLED
[NOTICE][LAN] 08-04-2021 09:21:24 wl1: interface state COUNTRY_UPDATE->ENABLED
[INFO][LAN] 08-04-2021 09:21:24 LAN sending RA to ff02::1
[INFO][VoIP] 08-04-2021 09:21:24 ReadGlobalSipConf ret=-2
[INFO][VoIP] 08-04-2021 09:21:24 Info Center Config Init...
[ERROR][LAN] 08-04-2021 09:21:24 Using interface wl1 with hwaddr 04:71:53:8a:ac:b2 and ssid "Vodafone-197216"
[NOTICE][LAN] 08-04-2021 09:21:24 wl1: interface state UNINITIALIZED->COUNTRY_UPDATE
[NOTICE][LAN] 08-04-2021 09:21:24 rfkill: Cannot open RFKILL control device
[ERROR][LAN] 08-04-2021 09:21:24 Configuration file: /tmp/wl1_hapd.conf
[INFO][System] 08-04-2021 09:21:23 Sync up with NTP Server failed.
[INFO][UMTS] 08-04-2021 09:21:23 Start Mobile 3G Successfully
[INFO][LAN] 08-04-2021 09:21:22 LAN sending RA to ff02::1
[NOTICE][LAN] 08-04-2021 09:21:22 wl0: AP-ENABLED
[NOTICE][LAN] 08-04-2021 09:21:22 wl0: interface state COUNTRY_UPDATE->ENABLED
[ERROR][LAN] 08-04-2021 09:21:22 Using interface wl0 with hwaddr 04:71:53:8a:ac:b1 and ssid "Vodafone-197216"
[NOTICE][LAN] 08-04-2021 09:21:22 wl0: interface state UNINITIALIZED->COUNTRY_UPDATE
[NOTICE][LAN] 08-04-2021 09:21:22 rfkill: Cannot open RFKILL control device
[ERROR][LAN] 08-04-2021 09:21:22 Configuration file: /tmp/wl0_hapd.conf
[INFO][WAN] 08-04-2021 09:21:20 bud update WAN5 status to 0.
[INFO][VoIP] 08-04-2021 09:21:20 cal_voip_get_binding_interface_id line 4385 wan id -1
[INFO][VoIP] 08-04-2021 09:21:20 ignore useless wan down
[INFO][VoIP] 08-04-2021 09:21:20 Voice binding wan_id is -1,binding_1 wan_id = -1,stop wan_id is 12,is_ipv6 = 0,default_wan_id= -1
[INFO][VoIP] 08-04-2021 09:21:20 can not get bind voice wan
[INFO][VoIP] 08-04-2021 09:21:20 ===start stop voice wan
[INFO][VoIP] 08-04-2021 09:21:19 cal_voip_get_binding_interface_id line 4385 wan id -1
[INFO][VoIP] 08-04-2021 09:21:19 ignore useless wan down
[INFO][VoIP] 08-04-2021 09:21:19 Voice binding wan_id is -1,binding_1 wan_id = -1,stop wan_id is 12,is_ipv6 = 1,default_wan_id= -1
[INFO][VoIP] 08-04-2021 09:21:19 can not get bind voice wan
[INFO][VoIP] 08-04-2021 09:21:19 ===start stop voice wan
[INFO][WAN] 08-04-2021 09:21:19 Stop WAN 12 IP Connection
[INFO][VoIP] 08-04-2021 09:21:19 Voice binding wan_id is -1,binding_1 wan_id = -1,stop wan_id is 13,is_ipv6 = 0,default_wan_id= -1
[INFO][LAN] 08-04-2021 09:21:19 LAN sending RA to ff02::1
[INFO][VoIP] 08-04-2021 09:21:19 Voice binding wan_id is -1,binding_1 wan_id = -1,stop wan_id is 13,is_ipv6 = 1,default_wan_id= -1
[INFO][WAN] 08-04-2021 09:21:18 Stop WAN 13 IP Connection
[INFO][WAN] 08-04-2021 09:21:18 WAN 4 Triggers Switching Partner To Stop Success
[INFO][LAN] 08-04-2021 09:21:18 LAN sending RA to ff02::1
[INFO][LAN] 08-04-2021 09:21:17 LAN sending RA to ff02::1
[INFO][VoIP] 08-04-2021 09:21:17 cal_voip_get_binding_interface_id line 4385 wan id -1
[INFO][VoIP] 08-04-2021 09:21:17 ignore useless wan down
[INFO][VoIP] 08-04-2021 09:21:17 Voice binding wan_id is -1,binding_1 wan_id = -1,stop wan_id is 6,is_ipv6 = 0,default_wan_id= -1
[INFO][VoIP] 08-04-2021 09:21:17 can not get bind voice wan
[INFO][VoIP] 08-04-2021 09:21:17 ===start stop voice wan
[INFO][VoIP] 08-04-2021 09:21:17 Voice binding wan_id is -1,binding_1 wan_id = -1,stop wan_id is 6,is_ipv6 = 1,default_wan_id= -1
[INFO][WAN] 08-04-2021 09:21:17 Stop WAN 6 IP Connection
[INFO][VoIP] 08-04-2021 09:21:17 Voice binding wan_id is -1,binding_1 wan_id = -1,stop wan_id is 7,is_ipv6 = 0,default_wan_id= -1
[INFO][LAN] 08-04-2021 09:21:16 LAN sending RA to ff02::1
[INFO][VoIP] 08-04-2021 09:21:16 cal_voip_get_binding_interface_id line 4385 wan id -1
[INFO][VoIP] 08-04-2021 09:21:16 ignore useless wan down
[INFO][VoIP] 08-04-2021 09:21:16 Voice binding wan_id is -1,binding_1 wan_id = -1,stop wan_id is 7,is_ipv6 = 1,default_wan_id= -1
[INFO][VoIP] 08-04-2021 09:21:16 can not get bind voice wan
[INFO][VoIP] 08-04-2021 09:21:16 ===start stop voice wan
[INFO][WAN] 08-04-2021 09:21:16 Stop WAN 7 IP Connection
[INFO][VoIP] 08-04-2021 09:21:16 Voice binding wan_id is -1,binding_1 wan_id = -1,stop wan_id is 11,is_ipv6 = 0,default_wan_id= -1
[INFO][VoIP] 08-04-2021 09:21:15 cal_voip_get_binding_interface_id line 4385 wan id -1
[INFO][VoIP] 08-04-2021 09:21:15 ignore useless wan down
[INFO][VoIP] 08-04-2021 09:21:15 Voice binding wan_id is -1,binding_1 wan_id = -1,stop wan_id is 11,is_ipv6 = 1,default_wan_id= -1
[INFO][VoIP] 08-04-2021 09:21:15 can not get bind voice wan
[INFO][VoIP] 08-04-2021 09:21:15 ===start stop voice wan
[INFO][WAN] 08-04-2021 09:21:15 Stop WAN 11 IP Connection
[INFO][WAN] 08-04-2021 09:21:15 bud update WAN9 status to 0.
[INFO][VoIP] 08-04-2021 09:21:15 Voice binding wan_id is -1,binding_1 wan_id = -1,stop wan_id is 9,is_ipv6 = 0,default_wan_id= -1
[INFO][VoIP] 08-04-2021 09:21:14 cal_voip_get_binding_interface_id line 4385 wan id -1
[INFO][VoIP] 08-04-2021 09:21:14 ignore useless wan down
[INFO][VoIP] 08-04-2021 09:21:14 Voice binding wan_id is -1,binding_1 wan_id = -1,stop wan_id is 9,is_ipv6 = 1,default_wan_id= -1
[INFO][VoIP] 08-04-2021 09:21:14 can not get bind voice wan
[INFO][VoIP] 08-04-2021 09:21:14 ===start stop voice wan
[INFO][WAN] 08-04-2021 09:21:14 Stop WAN 9 IP Connection
[INFO][WAN] 08-04-2021 09:21:14 bud update WAN11 status to 0.
[INFO][LAN] 08-04-2021 09:21:14 LAN sending RA to ff02::1
[INFO][WAN] 08-04-2021 09:21:14 bud update WAN4 status to 0.
[INFO][WAN] 08-04-2021 09:21:13 bud update WAN1 status to 0.
[INFO][LAN] 08-04-2021 09:21:13 LAN sending RA to ff02::1
[INFO][VoIP] 08-04-2021 09:21:13 cal_voip_get_binding_interface_id line 4385 wan id -1
[INFO][VoIP] 08-04-2021 09:21:13 ignore useless wan down
[INFO][VoIP] 08-04-2021 09:21:13 Voice binding wan_id is -1,binding_1 wan_id = -1,stop wan_id is 1,is_ipv6 = 0,default_wan_id= -1
[INFO][VoIP] 08-04-2021 09:21:13 can not get bind voice wan
[INFO][VoIP] 08-04-2021 09:21:13 ===start stop voice wan
[INFO][VoIP] 08-04-2021 09:21:12 cal_voip_get_binding_interface_id line 4385 wan id -1
[INFO][VoIP] 08-04-2021 09:21:12 ignore useless wan down
[INFO][VoIP] 08-04-2021 09:21:12 Voice binding wan_id is -1,binding_1 wan_id = -1,stop wan_id is 1,is_ipv6 = 1,default_wan_id= -1
[INFO][VoIP] 08-04-2021 09:21:12 can not get bind voice wan
[INFO][VoIP] 08-04-2021 09:21:12 ===start stop voice wan
[INFO][WAN] 08-04-2021 09:21:12 Stop WAN 1 IP Connection
[INFO][LAN] 08-04-2021 09:21:12 LAN sending RA to ff02::1
[INFO][LAN] 08-04-2021 09:21:11 LAN sending RA to ff02::1
[INFO][System] 08-04-2021 09:21:10 Starting MCPD OK.
[INFO][LAN] 08-04-2021 09:21:08 adapter hardware address 04:71:53:8a:ac:b0
[INFO][LAN] 08-04-2021 09:21:08 adapter index 18
[INFO][LAN] 08-04-2021 09:21:08 br0 (our ip) = 192.168.2.1
[INFO][LAN] 08-04-2021 09:21:08 Attaching option timezone to list
[INFO][LAN] 08-04-2021 09:21:08 Attaching option t2 to list
[INFO][LAN] 08-04-2021 09:21:08 Attaching option t1 to list
[INFO][LAN] 08-04-2021 09:21:08 adapter hardware address 04:71:53:8a:ac:c0
[INFO][LAN] 08-04-2021 09:21:08 adapter index 19
[INFO][LAN] 08-04-2021 09:21:08 br1 (our ip) = 192.168.3.1
[INFO][LAN] 08-04-2021 09:21:08 Attaching option lease to list
[INFO][LAN] 08-04-2021 09:21:08 Attaching option dns to existing member of list
[INFO][LAN] 08-04-2021 09:21:08 Attaching option dns to list
[INFO][LAN] 08-04-2021 09:21:08 Attaching option router to list
[INFO][LAN] 08-04-2021 09:21:08 Attaching option subnet to list
[INFO][LAN] 08-04-2021 09:21:08 Attaching option hostname to list
[INFO][LAN] 08-04-2021 09:21:08 Attaching option domain to list
[INFO][LAN] 08-04-2021 09:21:08 error on select
[INFO][LAN] 08-04-2021 09:21:08 udhcp server receive signal 12
[INFO][LAN] 08-04-2021 09:21:05 LAN sending RA to ff02::1
[INFO][System] 08-04-2021 09:21:05 Starting HTTP redirect OK.
[INFO][DNS] 08-04-2021 09:21:05 DNSMasq proxy server enable redirect
[INFO][System] 08-04-2021 09:21:05 Starting HTTP OK.
[INFO][LAN] 08-04-2021 09:20:24 LAN sending RA to ff02::1
[INFO][LAN] 08-04-2021 09:20:08 LAN sending RA to ff02::1
[INFO][LAN] 08-04-2021 09:19:52 LAN sending RA to ff02::1
[INFO][Firewall] 08-04-2021 09:19:46 Local Fragment Flood detect has been enabled on WAN ADSL-DATA.
[INFO][Firewall] 08-04-2021 09:19:46 Local Smurf Detect has been enabled on WAN ADSL-DATA.
[INFO][Firewall] 08-04-2021 09:19:46 Local Winnuke Detect has been enabled on WAN ADSL-DATA.
[INFO][Firewall] 08-04-2021 09:19:46 Local TCP FIN Flood Detect has been enabled on WAN ADSL-DATA.
[INFO][Firewall] 08-04-2021 09:19:46 Local TCP SYN Flood Detect has been enabled on WAN ADSL-DATA.
[INFO][Firewall] 08-04-2021 09:19:46 Local ICMP Flood Detect has been enabled on WAN ADSL-DATA.
[INFO][Firewall] 08-04-2021 09:19:46 Forward UDP Flood Detect has been enabled on WAN ADSL-DATA.
[INFO][Firewall] 08-04-2021 09:19:46 Local UDP Flood Detect has been enabled on WAN ADSL-DATA.
[EMERG][WAN] 08-04-2021 09:19:45 DSL link down.
[INFO][Firewall] 08-04-2021 09:19:44 Local Fragment Flood detect has been enabled on WAN ADSL-DT.
[INFO][Firewall] 08-04-2021 09:19:44 Local Smurf Detect has been enabled on WAN ADSL-DT.
[INFO][Firewall] 08-04-2021 09:19:44 Local Winnuke Detect has been enabled on WAN ADSL-DT.
[INFO][Firewall] 08-04-2021 09:19:44 Local TCP FIN Flood Detect has been enabled on WAN ADSL-DT.
[INFO][Firewall] 08-04-2021 09:19:44 Local TCP SYN Flood Detect has been enabled on WAN ADSL-DT.
[INFO][Firewall] 08-04-2021 09:19:44 Local ICMP Flood Detect has been enabled on WAN ADSL-DT.
[INFO][Firewall] 08-04-2021 09:19:44 Forward UDP Flood Detect has been enabled on WAN ADSL-DT.
[INFO][Firewall] 08-04-2021 09:19:44 Local UDP Flood Detect has been enabled on WAN ADSL-DT.
[INFO][Firewall] 08-04-2021 09:19:41 Local Fragment Flood detect has been enabled on WAN VDSL-DATA.
[INFO][Firewall] 08-04-2021 09:19:41 Local Smurf Detect has been enabled on WAN VDSL-DATA.
[INFO][Firewall] 08-04-2021 09:19:41 Local Winnuke Detect has been enabled on WAN VDSL-DATA.
[INFO][Firewall] 08-04-2021 09:19:41 Local TCP FIN Flood Detect has been enabled on WAN VDSL-DATA.
[INFO][Firewall] 08-04-2021 09:19:41 Local TCP SYN Flood Detect has been enabled on WAN VDSL-DATA.
[INFO][Firewall] 08-04-2021 09:19:41 Local ICMP Flood Detect has been enabled on WAN VDSL-DATA.
[INFO][Firewall] 08-04-2021 09:19:41 Forward UDP Flood Detect has been enabled on WAN VDSL-DATA.
[INFO][Firewall] 08-04-2021 09:19:41 Local UDP Flood Detect has been enabled on WAN VDSL-DATA.
[INFO][Firewall] 08-04-2021 09:19:39 Local Fragment Flood detect has been enabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:19:39 Local Smurf Detect has been enabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:19:39 Local Winnuke Detect has been enabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:19:39 Local TCP FIN Flood Detect has been enabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:19:39 Local TCP SYN Flood Detect has been enabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:19:39 Local ICMP Flood Detect has been enabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:19:39 Forward UDP Flood Detect has been enabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:19:39 Local UDP Flood Detect has been enabled on WAN VDSL-DT.
[INFO][Firewall] 08-04-2021 09:19:38 Local Fragment Flood detect has been enabled on WAN FTTH-IPTV.
[INFO][Firewall] 08-04-2021 09:19:38 Local Smurf Detect has been enabled on WAN FTTH-IPTV.
[INFO][Firewall] 08-04-2021 09:19:38 Local Winnuke Detect has been enabled on WAN FTTH-IPTV.
[INFO][Firewall] 08-04-2021 09:19:38 Local TCP FIN Flood Detect has been enabled on WAN FTTH-IPTV.
[INFO][Firewall] 08-04-2021 09:19:38 Local TCP SYN Flood Detect has been enabled on WAN FTTH-IPTV.
[INFO][Firewall] 08-04-2021 09:19:38 Local ICMP Flood Detect has been enabled on WAN FTTH-IPTV.
[INFO][Firewall] 08-04-2021 09:19:38 Forward UDP Flood Detect has been enabled on WAN FTTH-IPTV.
[INFO][Firewall] 08-04-2021 09:19:38 Local UDP Flood Detect has been enabled on WAN FTTH-IPTV.
[INFO][LAN] 08-04-2021 09:19:36 LAN sending RA to ff02::1
[INFO][Firewall] 08-04-2021 09:19:36 Local Fragment Flood detect has been enabled on WAN FTTH-DATA.
[INFO][Firewall] 08-04-2021 09:19:36 Local Smurf Detect has been enabled on WAN FTTH-DATA.
[INFO][Firewall] 08-04-2021 09:19:36 Local Winnuke Detect has been enabled on WAN FTTH-DATA.
[INFO][Firewall] 08-04-2021 09:19:36 Local TCP FIN Flood Detect has been enabled on WAN FTTH-DATA.
[INFO][Firewall] 08-04-2021 09:19:36 Local TCP SYN Flood Detect has been enabled on WAN FTTH-DATA.
[INFO][Firewall] 08-04-2021 09:19:36 Local ICMP Flood Detect has been enabled on WAN FTTH-DATA.
[INFO][Firewall] 08-04-2021 09:19:36 Forward UDP Flood Detect has been enabled on WAN FTTH-DATA.
[INFO][Firewall] 08-04-2021 09:19:36 Local UDP Flood Detect has been enabled on WAN FTTH-DATA.
[INFO][LAN] 08-04-2021 09:19:35 LAN sending RA to ff02::1
[INFO][Firewall] 08-04-2021 09:19:35 Local Frament Flood Detect has been enabled on LAN.
[INFO][Firewall] 08-04-2021 09:19:35 Local Smurf Detect has been enabled on LAN.
[INFO][Firewall] 08-04-2021 09:19:35 Local LAN Source Detect has been enabled.
[INFO][Firewall] 08-04-2021 09:19:35 Local Winnuke Detect has been enabled on LAN.
[INFO][Firewall] 08-04-2021 09:19:35 Local ICMP Flood Detect has been enabled on LAN.
[INFO][Firewall] 08-04-2021 09:19:35 Local UDP Flood Detect has been enabled on LAN.
[INFO][Firewall] 08-04-2021 09:19:35 UDP Bomb Detect has been enabled.
[INFO][Firewall] 08-04-2021 09:19:35 TCP Syn With Data Detect has been enabled.
[INFO][Firewall] 08-04-2021 09:19:35 IP Broadcast Source Detect has been enabled.
[INFO][Firewall] 08-04-2021 09:19:35 IP Land Detect has been enabled.
[INFO][Firewall] 08-04-2021 09:19:35 Port Scan Per IP Flood Detect has been enabled.
[INFO][Firewall] 08-04-2021 09:19:35 TCP FIN Per IP Flood Detect has been enabled.
[INFO][Firewall] 08-04-2021 09:19:35 TCP SYN Per IP Flood Detect has been enabled.
[INFO][Firewall] 08-04-2021 09:19:35 ICMP Per IP Flood Detect has been enabled.
[INFO][Firewall] 08-04-2021 09:19:35 UDP Per IP Flood Detect has been enabled.
[INFO][Firewall] 08-04-2021 09:19:35 IP Spoof Detect has been enabled.
[INFO][Firewall] 08-04-2021 09:19:35 Firewall Block Detect has been enabled.
[INFO][Firewall] 08-04-2021 09:19:35 Fireall Level has been set to Low.
[INFO][Firewall] 08-04-2021 09:19:35 Forward L2TP Rule has been flushed.
[INFO][Firewall] 08-04-2021 09:19:35 Forward PPTP Rule has been flushed.
[INFO][DNS] 08-04-2021 09:19:35 Not a property wan_id.
[WARNING][DNS] 08-04-2021 09:19:35 ignoring nameserver 127.0.0.1 - local interface
[WARNING][DNS] 08-04-2021 09:19:35 ignoring nameserver ::1 - local interface
[INFO][DNS] 08-04-2021 09:19:35 Starting DNSMasq proxy server OK.
[INFO][LAN] 08-04-2021 09:19:35 Starting RADVD Server OK.
[INFO][LAN] 08-04-2021 09:19:34 Starting DHCPV6 Server OK.
[INFO][LAN] 08-04-2021 09:19:32 Opening listen socket on 0x00000000:67 br1
[INFO][LAN] 08-04-2021 09:19:32 adapter hardware address 3a:32:d0:6b:46:e3
[INFO][LAN] 08-04-2021 09:19:32 adapter index 19
[INFO][LAN] 08-04-2021 09:19:32 br1 (our ip) = 192.168.3.1
[INFO][LAN] 08-04-2021 09:19:32 Read 0 leases
[INFO][LAN] 08-04-2021 09:19:32 Opening listen socket on 0x00000000:67 br0
[INFO][LAN] 08-04-2021 09:19:32 no_of_ifaces:1
[INFO][LAN] 08-04-2021 09:19:32 Attaching option timezone to list
[INFO][LAN] 08-04-2021 09:19:32 Attaching option t2 to list
[INFO][LAN] 08-04-2021 09:19:32 Attaching option t1 to list
[INFO][LAN] 08-04-2021 09:19:32 Attaching option lease to list
[INFO][LAN] 08-04-2021 09:19:32 adapter hardware address 04:71:53:8a:ac:b0
[INFO][LAN] 08-04-2021 09:19:32 adapter index 18
[INFO][LAN] 08-04-2021 09:19:32 br0 (our ip) = 192.168.2.1
[ERROR][LAN] 08-04-2021 09:19:32 Unable to open /var/udhcpd14.leases for reading
[INFO][LAN] 08-04-2021 09:19:32 no_of_ifaces:2
[INFO][LAN] 08-04-2021 09:19:32 Attaching option dns to existing member of list
[INFO][LAN] 08-04-2021 09:19:32 Attaching option dns to list
[INFO][LAN] 08-04-2021 09:19:32 Attaching option router to list
[INFO][LAN] 08-04-2021 09:19:32 Attaching option subnet to list
[INFO][LAN] 08-04-2021 09:19:32 Attaching option hostname to list
[INFO][LAN] 08-04-2021 09:19:32 Attaching option domain to list
[INFO][LAN] 08-04-2021 09:19:32 udhcp server (v0.9.7) started
[INFO][LAN] 08-04-2021 09:19:32 Starting DHCP Server OK.
[EMERG][WAN] 08-04-2021 09:19:29 DSL link down.
[INFO][WAN] 08-04-2021 09:19:28 Starting DSL PHY OK.
[INFO][System] 08-04-2021 09:19:26 Starting TR069 OK.
[INFO][System] 08-04-2021 09:19:26 Boot up successfully, duration is 21 seconds, reboot cause is Web Restore Default
[WARNING][System] 08-04-2021 09:19:26 No TR069 Client Registered
[WARNING][System] 08-04-2021 09:19:25 No TR069 Client Registered
am 05.08.2021 12:22
Hey @Marv_Vox,
bitte schick mir doch mal eine PN mit Kundennummer, Name, Adresse (inkl Bundesland) und Geburtsdatum des Anschlussinhabers zu.
Dann können wir uns das genauer anschauen.
Boris
