am 11.10.2020 21:22 - zuletzt bearbeitet am 12.10.2020 10:37 von akoch
Ab 4-6 tage GigaCube Verbindung immer unterbrochen, Gerät neu gestartet.
In der LOG-Datei "Sync time failed from BBOU" und danach der Neustart.
74427 Fichtenberg (Hornberg)
Device name: B528s-23a
IMEI: ***
IMSI : ***
My number: Unknown
Hardware version: WL1B520FM02
Software version: 81.195.03.22.11
Web UI version: 21.100.52.00.03
LAN MAC address: ***
WAN IP address: ***
WAN IPv6 Address: Unknown
CELL_ID: 18161665
RSRQ: -7dB
RSRP: -100dBm
SINR: 1dB
PLMN: 26202
2020-10-11 19:35:39 System Notice Device 64:**:**:ed:**:b3 connect gigacube-E30A
2020-10-11 19:35:09 System Notice Device e4:**:**:f1:**:a1 connect gigacube-E30A
2020-10-11 19:35:09 System Notice Device 00:**:**:89:**:ff connect gigacube-E30A
2020-10-11 19:34:44 System Notice WAN connection INTERNET_R_UMTS1:IPv6 failed
2020-10-11 19:34:44 System Notice WAN connection INTERNET_R_UMTS1:IPv4 connected
1970-01-01 00:11:32 System Notice Sync time failed from BBOU
2020-10-11 19:24:48 System Notice Device 00:**:**:89:**:ff connect gigacube-E30A
2020-10-11 19:24:18 System Notice Device 64:**:**:ed:**:b3 connect gigacube-E30A
2020-10-11 19:24:18 System Notice Device e4:**:**:f1:**:a1 connect gigacube-E30A
2020-10-11 19:23:23 System Notice WAN connection INTERNET_R_UMTS1:IPv6 failed
2020-10-11 19:23:23 System Notice WAN connection INTERNET_R_UMTS1:IPv4 connected
1970-01-01 00:00:09 System Notice Sync time failed from BBOU
2020-10-11 18:33:18 System Notice Device 04:**:**:60:**:01 disconnect gigacube-E30A
2020-10-11 18:32:48 System Notice Device 04:**:**:60:**:01 connect gigacube-E30A
2020-10-11 18:26:45 System Notice Device 2c:**:**:26:**:86 connect gigacube-E30A
2020-10-11 18:24:44 System Notice Device e4:**:**:f1:**:a1 connect gigacube-E30A
2020-10-11 18:24:14 System Notice Device 00:**:**:89:**:ff connect gigacube-E30A
2020-10-11 18:24:14 System Notice Device 64:**:**:ed:**:b3 connect gigacube-E30A
2020-10-11 18:23:44 System Notice Device 00:**:**:73:**:d4 connect gigacube-E30A
2020-10-11 18:23:19 System Notice WAN connection INTERNET_R_UMTS1:IPv6 failed
2020-10-11 18:23:19 System Notice WAN connection INTERNET_R_UMTS1:IPv4 connected
1970-01-01 10:02:50 System Notice Sync time failed from BBOU
2020-10-11 18:22:46 System Notice Device 64:**:**:ed:**:b3 connect gigacube-E30A
2020-10-11 18:22:46 System Notice Device 04:**:**:60:**:01 connect gigacube-E30A
2020-10-11 18:04:09 System Notice Device 04:**:**:60:**:01 disconnect gigacube-E30A
2020-10-11 18:03:39 System Notice Device 04:**:**:60:**:01 connect gigacube-E30A
2020-10-11 17:54:05 System Notice Device 04:**:**:60:**:01 disconnect gigacube-E30A
2020-10-11 17:53:34 System Notice Device 04:**:**:60:**:01 connect gigacube-E30A
2020-10-11 17:47:32 System Notice Device 2c:**:**:26:**:86 connect gigacube-E30A
2020-10-11 17:42:00 System Notice Device 04:**:**:60:**:01 disconnect gigacube-E30A
2020-10-11 17:42:00 System Notice Device e4:**:**:f1:**:a1 connect gigacube-E30A
2020-10-11 17:41:30 System Notice Device 00:**:**:73:**:d4 connect gigacube-E30A
2020-10-11 17:41:30 System Notice Device 00:**:**:89:**:ff connect gigacube-E30A
2020-10-11 17:41:30 System Notice Device 04:**:**:60:**:01 connect gigacube-E30A
2020-10-11 17:41:05 System Notice WAN connection INTERNET_R_UMTS1:IPv6 failed
2020-10-11 17:41:05 System Notice WAN connection INTERNET_R_UMTS1:IPv4 connected
1970-01-01 09:20:35 System Notice Sync time failed from BBOU
2020-10-11 17:34:16 System Notice Device e4:**:**:f1:**:a1 connect gigacube-E30A
2020-10-11 17:33:16 System Notice Device 00:**:**:73:**:d4 connect gigacube-E30A
2020-10-11 17:33:16 System Notice Device 00:**:**:89:**:ff connect gigacube-E30A
2020-10-11 17:32:51 System Notice WAN connection INTERNET_R_UMTS1:IPv6 failed
2020-10-11 17:32:51 System Notice WAN connection INTERNET_R_UMTS1:IPv4 connected
1970-01-01 09:12:21 System Notice Sync time failed from BBOU
2020-10-11 17:31:50 System Notice Device e4:**:**:f1:**:a1 connect gigacube-E30A
2020-10-11 17:30:50 System Notice Device 00:**:**:73:**:d4 connect gigacube-E30A
2020-10-11 17:30:50 System Notice Device 00:**:**:89:**:ff connect gigacube-E30A
2020-10-11 17:30:25 System Notice WAN connection INTERNET_R_UMTS1:IPv6 failed
2020-10-11 17:30:25 System Notice WAN connection INTERNET_R_UMTS1:IPv4 connected
1970-01-01 09:09:55 System Notice Sync time failed from BBOU
2020-10-11 17:29:45 System Notice Device 00:**:**:89:**:ff connect gigacube-E30A
2020-10-11 17:25:14 System Notice Device e4:**:**:f1:**:a1 connect gigacube-E30A
2020-10-11 17:24:44 System Notice Device 00:**:**:73:**:d4 connect gigacube-E30A
2020-10-11 17:24:19 System Notice WAN connection INTERNET_R_UMTS1:IPv6 failed
Netz oder hardware problem? Hilfe.....
MFG Kalo
Edit: sensible Daten entfernt.
Betreff um PLZ/Ort/Station ergänzt (akoch)
am 12.10.2020 10:41
An der von dir immer belegten Station sind keine Einschränkungen vorhanden.
Tippe auf deinen GC.
Diesen mal auf Factory Reset testen.
Kein Support via PN !!am 12.10.2020 11:28
Ich habe schon 2x Factory reset gemacht.
Wenn Station ist in ordnung, meine GigaCube modem (2 jahre alt) ist kaput...
Wie kann ich austauschen?
In letzte LOG: User press button shutdown aber es ist 2m hoch, niemand hat gedruckt...
2020-10-12 11:20:52 User Notice User admin login from 192.168.8.158 successfully 2020-10-12 11:20:34 System Notice WAN connection INTERNET_R_UMTS1:IPv6 failed 2020-10-12 11:20:34 System Notice WAN connection INTERNET_R_UMTS1:IPv4 connected 1970-01-01 15:57:20 System Notice Sync time failed from BBOU 2020-10-12 11:20:02 User Notice User press button shutdown 2020-10-12 11:20:02 User Notice user press power button 2020-10-12 11:19:48 System Notice WAN connection INTERNET_R_UMTS1:IPv6 failed 2020-10-12 11:19:48 System Notice WAN connection INTERNET_R_UMTS1:IPv4 connected 1970-01-01 15:56:34 System Notice Sync time failed from BBOU 2020-10-12 11:19:18 User Notice User press button shutdown 2020-10-12 11:19:18 User Notice user press power button 2020-10-12 11:19:16 System Notice Device e4:**:**:f1:**:a1 connect gigacube-E30A 2020-10-12 11:18:51 System Notice WAN connection INTERNET_R_UMTS1:IPv6 failed 2020-10-12 11:18:51 System Notice WAN connection INTERNET_R_UMTS1:IPv4 connected 1970-01-01 15:55:37 System Notice Sync time failed from BBOU 1970-01-01 15:54:32 User Notice User press button shutdown 1970-01-01 15:54:32 User Notice user press power button 1970-01-01 15:54:30 System Notice Sync time failed from BBOU 2020-10-12 11:10:27 User Notice User press button shutdown 2020-10-12 11:10:27 User Notice user press power button 2020-10-12 11:10:15 System Notice WAN connection INTERNET_R_UMTS1:IPv6 failed 2020-10-12 11:10:15 System Notice WAN connection INTERNET_R_UMTS1:IPv4 connected 1970-01-01 15:47:01 System Notice Sync time failed from BBOU
MFG Janos
am 13.10.2020 08:36
Das Problem ist immer noch da....
MFG Kalo
am 13.10.2020 18:12
Hi Kalo,
ist Dein Gigacube schon über den 2 Jahren Gewährleistung? Also wann erhalten?
Hast Du ggf. noch andere Mobilnummern im Vodafone-Netz, wenn ja machen diese über mobile Daten die identischen Probleme oder wirklich nur der Gigacube?
Inken
am 13.10.2020 19:51
ab 02.09.2018 schon über 2 jahre.
Ich habe nur GigaCube vertrag, ohne Mobilnummer.
MFG Janos
am 16.10.2020 15:19
Hallo Kalo,
wenn Dein GigaCube schon über 2 Jahre alt ist, dann ist gibt es hierfür keine Gewährleistung mehr. Die Zeit der Gewährleistung ist 2 Jahre.
Wenn Du sicher gehen willst, das der Cube die Ursache ist, dann teste das Gerät mehrere Kilometer entfernt, da sich das Gerät dann in eine andere Mobilfunkstation einbucht.
T-Jay
