Hi I want to use port forwarding, but I don't see the port forwarding section, does anyone know a so
choyoungoh
Hi I want to use port forwarding, but I don't see the port forwarding section, does anyone know a solution? I am using vodafone easybox 805, I don't know what the problem is but I can't see port forwarding, do I need to change my plan to use this or do I need to buy a new router?
2 Antworten 2
Gelöschter User
Nicht anwendbar
Maybe this will help.
RobertP
portforwarding is only possible if you have a public IPv4
your connection is established with DS Lite  (IPv4-Address = No IP available)
use IPv6 or try to contact support for a change to dual stack
