am 04.03.2019 18:59
Hello. Sorry i dont speak english well enough so ill post on english. Hope you dont mind.
Here is a question:
Ive moved from Munich to Buhl and with my Gigbacube I have low speed and bad pings so i am considering buying wifi antenna. Does anybody have any recomendation on what to buy and what good is it? How much can I even expect from it? Thank you
am 04.03.2019 20:25
It depends on the local network quality and the used frequencies.
The only thing - you need an antenna with two TS9 connectors (or at least an appropriate adapter converting the antenna to two TS9 connectors).
05.03.2019 09:27 - bearbeitet 05.03.2019 09:41
Hello,
to make it clear - you do not need a wifi-antenna but an antenna for the LTE-network. If you post the adress you want to use the Gigacube (without housenumber) here maybe one can lookup which frequencies are in use there and which antenna suits best.. .
Connector was mentioned before - important.
am 06.03.2019 12:04
You don't need a wifi antenna but a broadband lte antenna like the Panorama LTE MIMO universal HighGain. The Antenna has to mounted outside and directed to the sender.
