am 16.02.2019 17:36
am 17.02.2019 01:47
If you use the MIC the 7530 will be installed automatic and you had nothing to do with the prefix.
Watch at the welcome papers ...there was the manual informations like:
vodafone-vdsl.komplett/vf1234567890 with a password. "vodafone-vdsl.komplett/" was an example for the Prefix.
You need it only when you install the 7530 manually
Better reset the fritzbox and use the actual MIC and choose automatic with mic in the box.
am 17.02.2019 07:51
am 18.02.2019 10:19
Hello Surender,
the error code basically means that the dial-in data is wrong. However, there may be other reasons. Have you already phoned our colleagues?
Best Regards
Sebastian
am 18.02.2019 19:10
am 19.02.2019 10:21
Hello Surender,
all right. Then keep us here gladly up to date.
Best Regards
Sebastian
