Archiv_Störungsmeldungen-Internet-TV-Telefon-DSL
Siehe neueste
ständige Verbindungsabbrüche
Highlighted
Seit einigen Tagen (und heute besonders) have ich ständig DSL Verbindungsabbrüche. Teilweise finden diese alle paar Minuten statt.
Es ist übrigens eine DSL 6000 Leitung.
Hier ein Auszug aus dem Log:
06/28/2012  09:26:15 ADSL Media Up !
06/28/2012  09:26:03 Can't find NTP time.
06/28/2012  09:25:59 Duplicate user login from 192.168.2.20
06/28/2012  09:25:54 Get system time from NTP server:88.198.197.205.
06/28/2012  09:25:54 Can't find NTP time.
06/28/2012  09:25:45 Get system time from NTP server:192.53.103.108.
06/28/2012  09:25:45 Can't find NTP time.
06/28/2012  09:25:40 If(PPPoE2) stop
06/28/2012  09:25:38 Duplicate user login from 192.168.2.20
06/28/2012  09:25:38 If(PPPoE2) stop PPP
06/28/2012  09:25:36 Get system time from NTP server:131.234.137.23.
06/28/2012  09:25:36 Can't find NTP time.
06/28/2012  09:25:35 If(PPPoE1) stop
06/28/2012  09:25:33 If(PPPoE1) stop PPP
06/28/2012  09:25:29 ADSL Media Down !
06/28/2012  09:25:27 Get system time from NTP server:
06/28/2012  09:25:11 If(PPPoE1) PPP connection ok !
06/28/2012  09:25:10 If(PPPoE2) PPP connection ok !
06/28/2012  09:25:10 If(PPPoE1) get secondary DNS IP:
06/28/2012  09:25:10 If(PPPoE1) get primary DNS IP:
06/28/2012  09:25:10 If(PPPoE1) get IP:
06/28/2012  09:25:09 If(PPPoE2) get secondary DNS IP:
06/28/2012  09:25:09 If(PPPoE2) get primary DNS IP:
06/28/2012  09:25:09 If(PPPoE2) get IP:
06/28/2012  09:25:09 If(PPPoE1) start PPP
06/28/2012  09:25:09 If(PPPoE1) receive PADS
06/28/2012  09:25:09 If(PPPoE2) start PPP
06/28/2012  09:25:09 If(PPPoE2) receive PADS
06/28/2012  09:25:09 If(PPPoE1) send PADR
06/28/2012  09:25:09 If(PPPoE1) receive PADO
06/28/2012  09:25:09 If(PPPoE2) send PADR
06/28/2012  09:25:09 If(PPPoE2) receive PADO
06/28/2012  09:25:08 If(PPPoE1) send PADI
06/28/2012  09:25:08 If(PPPoE2) send PADI
06/28/2012  09:25:03 If(PPPoE2) send PADI
06/28/2012  09:25:03 If(PPPoE1) send PADI
06/28/2012  09:25:03 ADSL Media Up !
Hier der DSL-Status der Easybox 803 mit 216 Firmware:
Upstream	Downstream
733 (Kbps.)	6911 (Kbps.)
Operation Data	Upstream	Downstream
Noise Margin	13.7 dB	        6.5 dB
Attenuation	16.6 dB	        30.3 dB
Indicator Name	Near End Indicator	Far End Indicator
FEC Error	22659	                0
CRC Error	213	                0
HEC Error	2454	                67
Statistiken: 	Transmitted Cells	Received Cells
Cell Counter	45302	                17548
 Kann da jemand eine Einschätzung / Ratschlag abgeben?
5 Antworten 5
Highlighted
Highlighted
Hatte ich gelesen, war mir aber nicht sicher ob "eingeschränkte" Performance mit ständigen Abbrüchen einher geht.
Highlighted
also ich denke schon.Bei mir treten beide Probleme auf.Schlechter Download und Verbindungsabbrüche.
Highlighted
Dein Rauschabstand ist zu gering im Download.
Meines Wissen nach sind 6dB absolutes Minimum, die EasyBoxen sind aber nicht dafür bekannt, dass sie sonderlich gut mit geringen Signalpegeln klar kommen.
Versuch, erstmal deine ganzen Steckverbindungen zwischen Box und TAE neu zu stecken.
Hast du die Probleme schon immer oder sind die plötzlich aufgetreten? Wenn plötzlich, dann könnte es ein Schaden in der Leitung/im Verteiler sein.
Highlighted
Probleme kamen plötzlich und hauptsächlich Abends/WE. Techniker hat inzwischen die Leitung von 6000 auf 3500 gedrosselt. Funktioniert nun alles, toll ist es mit dem Speed aber nicht.
