Wifi not working
Aimagar
Hello,
Sorry for speaking in English, I am new in Germany.
Yesterday I switched off the router for a couple of minutes, but the wifi has not come back yet. Internet works fine with the cable. Anyone from Vodafone who could help me? Thank you.
Best,
Aixa
Jens
Hello Aixa,
the wifi option is booked since friday. Did it works now?
Regards
Jens
14 Antworten 14
Andre
Ex-Moderator:in
Ex-Moderator:in
Hey Aimagar,
which router model are you using?
The easybox 804 for example has a wlan on/off key on the left side. May be you've deactivated WLAN this way?
Otherwise i would try to reset the router to factory defaults.
To send you a proper instructions , i'll need the exact model.
Best regards,
Andre
Aimagar
Hey Andre,
I am not at home at the moment so I cannot check the exact model, but it is the basic one. It does have a button to activate/deactivate the WLAN. I have pressed it but it still does not work. I will send you the exact details later today. Thank you.
Best,
Aixa
Aimagar
Hello,
The model is FAST 5460. Thank you.
Best,
Aixa
Stephan
Hi Aimagar,
is there no WLAN displayed at all or do you just not get a connection?
Regards
Stephan
Aimagar
No WLAN at all. The light of the WLAN button is off. The only way I can connect to internet is through the cable.
Best,
Aixa
Aimagar
Hi Stephan,
Have you already reset the router? The WLAN is still not working.
Best,
Aixa
Moni_GK
Hello, Aimagar,
I would like to have a look at the device. Please send me your customer data (name, customer number, address and date of birth) as PN.
Please contact me here again when you have sent the data.
Best regards
Moni
Aimagar
Sent.
Moni_GK
Hello, Aimagar,
in your contract, the Wi-Fi isn't booked, so the LED doesn't come on.
I can book it for you. WLAN then costs 2,99€ per month. Of course you can also switch your own WLAN router behind the device and create WLAN with it.
Best regards
Moni
