- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
am
28.05.2020
13:45
- zuletzt bearbeitet am
28.05.2020
19:16
von
Mav1976
Hi community,
I'm looking for a solution to solve my problem.
I joined the wifi product. Even though I have tried the factory setting several times, It still didn't work .: shock:
And I cannot find the light on the wifi and WPS.
when I start the device, wifi and WPS lights blinked several times. finally, it turns off and it doesn't come back.
Please give me solution to solve this wifi issue.
*** @ORSLOW @ , thread moved from IoT to cable! ***
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
28.05.2020 19:19 - bearbeitet 28.05.2020 19:21
I'm not confident with cable but I found the Vodafone station on the website published by two vendors (Arris and Technicolor /manuals in German only). Can you find out of what vendor your router is?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
28.05.2020 18:37 - bearbeitet 28.05.2020 19:12
Hi @ORSLOW,
What kind of internet contract (DSL or cable) do you use?
It seems that you use a cable connection. I will move your thread into the correct board.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 28.05.2020 19:51
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 28.05.2020 19:55
My circuit is CABLE.
Thanks
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
28.05.2020 20:04 - bearbeitet 28.05.2020 20:23
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 29.05.2020 13:32
of course. I did. but I can not find the WLAN tab in Default Gateway.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 29.05.2020 14:00
Hi @ORSLOW,
Please press the the WiFi button (VF station) at least 3 seconds. The LEF light should start to blink. When the light is solid then your WiFi should enabled.
If the Wi‑Fi LED on the front panel is off then press and hold the Wi‑Fi button for
approximately three seconds until the Wi‑Fi LED lights up.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 29.05.2020 17:08
Hi Mav1976,
I have tried several times. the lights still turn off.
Actually, I have no idea what am I to do more.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 30.05.2020 11:00
Hello ORSLOW,
I'd be happy to take a look and see what I find.
Please send me a PN with your customer data (name, address, customer number and date of birth).
Then please contact me again here when you have sent me the data.
Best regards
Moni
