WiFi problems
fotoramic
Digitalisierer
Digitalisierer
Hi, I’m having problems with my router , the WiFi sometimes gets super slow like 20kb/sek and devices get randomly disconnected, I’ve already checked devices and that’s you’re routers fault... I’ve restarted and resetted router , that doesn’t help . Please fix this !
Hi fotoramic,
well, we could try to switch the modem, are you okay with that?
Regards
9 Antworten 9
Manu
Hi fotoramic,
how did you find out it was a router failure? Which router do you have?
Is LAN sometimes affected or only WLAN?
Can you also tell us with which devices the malfunctions occur?
Best Regards, Manu
fotoramic
Digitalisierer
Digitalisierer
I’ve contacted and tested all my devices so all the manufacturers told me to change router ...
Devices that has been tested and had problems
* 2x iPhone 7plus
* iPad Pro
* iRobot
* Samsung cw460 Printer
* 2x Windows Laptops
I’m using only wlan so I’m not sure about the LAN problems
The model I’m using is CBN CH6640E , I’m 90% sure, it’s just in a pretty hard to reach place so I googled and this looks the same 🙂
Hi fotoramic,
Regards
fotoramic
Digitalisierer
Digitalisierer
I’m ok with everything that will fix the problem , not make it bigger 😄
the modem should arrive you in a few days 😉 Remember to send back the old modem.
Regards
fotoramic
Digitalisierer
Digitalisierer
I will receive some sending instructions with the new modem ? 🙂
yeah it should be inside the package. 🙂
Regards
fotoramic
Digitalisierer
Digitalisierer
Thanks, for the new router today, so far it seems to be good. And I will send the old one back tomorrow 🙂 so thank you for you’re help ! 🙂
Hi fotoramic,
alright, im gonna close this thread then 😉
Regards
