WiFi connection does not work sometimes
Vishal
Hello,
I have been using Vodafone Internet connection since last 6 months and I have noticed that sometimes WiFi network just stops working. The internet via ethernet cable still works. I try rebooting my device as well as WiFi router, but network does not work. And it automatically starts working again. A friend of mine has a similar problem, and he got it fixed by updating the WiFi router firmware provided by vodafone. My current wifi route firmware version is 4.50.20.3. Please help me to fix this problem.
Thanks,
Vishal
Hello Vishal,
what kind of WiFi devices do you use? Have you tried a factory reset of the modem? How long does it take the devices to reconnect to your WiFi?
Kind regards
