am 08.04.2019 16:17
Good afternoon,
I had Vodafone Kabel Deutschland for 2 weeks now, and since day 1 I have problems calling via Whatsapp when connected to the WLAN. I manage to call, but the call immediately drops. I do not have this problems with 4G, and I get very fast speed with any other service (Youtube, Netflix, Skype etc...). Anybody else has the same issue?
am 15.05.2019 15:42
Hello Paolo,
since the problem solved itself, I'll close your post now.
Best regards
Tina
am 10.04.2019 11:29
Hello pcazzoletti,
do you have another device (repeater) connected to our hardware?
Best regards
Tina
am 10.04.2019 11:56
Hi Tina,
thanks for the answer. No nothing is connected
am 12.04.2019 08:49
Hallo pcazzoletti,
does that happen on different contacts you call?
Best regards
Tina
am 16.04.2019 10:03
Yes it was happening with everybody but apparently the issue solved by itself. Thanks for your help
Paolo
am 17.04.2019 21:54
Hello pcazzoletti,
I'm glad to hear it. May I ask what helped in the end?
If it's ok for you, I'll close the thread here.
Love greetings
Moni
am 18.04.2019 10:33
I am not sure what helped...It just started working. You can close the thread, yes.
am 15.05.2019 15:42
Hello Paolo,
Best regards
Tina
