VoIP technology with my cable internet contract
Petushkou
Youngster
Youngster
Hello Vodafone,
I would like to make calls to mobile and stationary phones using a VoIP technology with my cable internet contract.
I cannot do this at the moment, looks like it does not work.
Could you please have a look at my contract and kindly advise me further actions regarding this.
Thank you.
Edit @Petushkou, moved your thread to the right board.
Wallace
Ex-Moderator:in
Ex-Moderator:in
Hi Petushkou,
You can only use VoIP with our connections if you activate bridge mode in the customer portal and then connect your own Wifi router to the cable modem. You can also buy your own cable router and set up VoIP on it. At the moment you can only operate the following cable routers on our connections: FRITZ!Box 6430, 6490 or 6590.
Regards
Wallace
