Upload speed deteriorates in the afternoon
wealas
I just switched to the CableMax 1000 from Red Internet 1000 and changed to the Fritzbox 6591 modem (from the Arris tg3442de) and now every afternoon the upload channels go down to 4QAM (from 32QAM in the morrning) and upload speed goes down to 8-10 Mbit/s. Download seems erratic as well with ping going up to 1000ms under load.
Only change on my side is the modem itself, not even the cables have changed.
And I did not have those problems before the change.
Could someone check the status remotely, please?
Thanks!
Martin59
Hi wealas,
an interfering signal has been removed, which has led to the improvement.
How is it currently?
Best regards, Martin
23 Antworten 23
wealas
This morning upstream did not go back to normal, all 4 channels are on 4QAM and upload is around 8 Mbps.
Tried factory reset of the modem but no change.
Tried the old modem but it seems that one is deprovisioned so I couldn't test the speed.
wealas
Here is the questionaire and some screenshots. Right now the connection is very bad.
Vertrag: CableMax 1000
Modem/ Router: FritzBox 6591
Leih-Gerät oder eigenes Gerät: Leih-Gerät
Fehler: Slow upload and low upstream channel quality, speedtest: https://www.nperf.com/r/3244075088634527-PErKlyrH
Wie verbunden: LAN
Browser: Chrome
Betriebssystem: Linux (Debian)
Beginn Zeitraum: 10.03.2020
Signalwerten: https://imgur.com/a/b88hwfu
Störungshotline: none
I would really appreciate some help!
Thanks!
Wallace
Ex-Moderator:in
Ex-Moderator:in
Hi wealas,
I like to check on the line. Send me your customer data (name, address, customer number, birthday) in a private message and let me know here that you have transmitted the data.
Regards
Wallace
wealas
PM sent, thanks!
Ex-Moderator:in
Ex-Moderator:in
Hello wealas,
there is a problem in the return path, some noise makes the upload rate drop. There is a task with an appointment for a technician today, I made a fault report for you and assigned it to this task.
Kind regards
wealas
Hello,
thank you!
Would it also be possible to cancel the tarif change and go back to my previous contract Internet RED 1000 with the price I paid before?
Ex-Moderator:in
Ex-Moderator:in
Hello wealas,
you may cancel the tariff change within 14 days starting on March 9th.
Kind regards,
wealas
The ticket was just closed and the internet is alful at the moment. There were few hours yesterday when things were improving but around 20:00 upstream channels all went back to 4QAM and have not changed since.
Could you check why the ticket was closed and maybe open a new one?
Attached is a speed test from few minutes ago, 0.044mb/s upstream 🙂
Manu
Ex-Moderator:in
Ex-Moderator:in
Hi wealas,
the technicians located and removed the interference yesterday.
Can you connect our router? Then I can check the line again.
Best Regards, Manu
