Slow internet every evening
GELÖST
Gehe zu Lösung
Hello!
I am using tarif for 200 MBits and I can get this speed only during late nights. I checked my router, drivers, adjusted router to use channels which nobody around me uses. So in the end at night (I guess it is rush hour) I get speed of 1-2 MBits and later at night around 100. So how can it be fixed because the actual speed is 100 time smaller than supposed.
Best,
Muldashev
Edit: Contribution pushed into the matching board
Ex-Moderator
Hi Muldashev,
Thanks for your private message.
I have found out that the degree of capacity utilization in your area is fairly high at certain times. That's why our technicians are extending the lines. They should be finished by the end of April.
If you are okay with that I will give you a discount.
Kind regards,
Sebastian
Alles Easy How To Hilfe !
4 Antworten 4
Ex-Moderator
Hi Muldashev,
There seems to be something wrong.
Please send me your full name, address and customer ID via a private message. After that I will check your connection.
Kind regards,
Sebastian
Ex-Moderator
Hi Muldashev,
Kind regards,
Sebastian
Highlighted
Hi Sebastian,
thank you for reply. If it is to be finished in next month I agree.
Best regards,
Muldashev
Ex-Moderator
Hi Muldashev,
Okay, the discount will appear on your bill for April.
Kind regards,
Sebastian
