am 28.10.2014 12:17
langsam bin ich am verzweifeln und weiß mit meinem Anschluss nicht mehr so recht weiter .Seit einigen Wochen gibt es Verbindungsabbrüche zu den verschiedensten Zeit .Manchmal so massiv das ich alle paar sek rausfliege ....mein Problem bezieht sich hauptsächlich auf Steam und den Ts3.Im Internet kann ich sonst ganz normal surfen .
Logbuch:
10/28/2014 12:12:44 192.168.2.103 login success
10/28/2014 12:12:44 User from 192.168.2.103 timed out
10/28/2014 11:46:23 192.168.2.103 login success
10/28/2014 11:46:15 192.168.2.103 login fail
10/28/2014 11:30:30 sending ACK to 192.168.2.102
10/28/2014 11:26:01 sending ACK to 192.168.2.103
10/28/2014 08:24:47 **UDP Loop** 93.180.5.26, 57704->> 188.100.82.209, 19 (from PPPoE1 Inbound)
10/28/2014 07:28:49 NTP Date/Time updated.
10/28/2014 07:27:58 Get system time from NTP server:217.79.179.106.
10/28/2014 07:16:48 Wireless C8:E0:EB:87:E3:7E released
10/28/2014 06:26:17 **UDP Loop** 74.82.47.33, 55355->> 188.100.82.209, 19 (from PPPoE1 Inbound)
10/28/2014 00:33:28 Wireless 24:EC:99:DD:68:1C released
10/28/2014 00:28:14 sending ACK to 192.168.2.100
10/27/2014 22:46:17 192.168.2.103 logout
10/27/2014 22:45:21 If(PPPoE1) PPP connection ok !
10/27/2014 22:45:19 If(PPPoE1) get secondary DNS IP:195.50.140.248
10/27/2014 22:45:19 If(PPPoE1) get primary DNS IP:195.50.140.118
10/27/2014 22:45:19 If(PPPoE1) get IP:188.100.82.209
10/27/2014 22:45:19 If(PPPoE1) start PPP
10/27/2014 22:45:19 If(PPPoE1) receive PADS
10/27/2014 22:45:19 If(PPPoE1) send PADR
10/27/2014 22:45:19 If(PPPoE1) receive PADO
10/27/2014 22:45:19 If(PPPoE1) send PADI
10/27/2014 22:45:15 If(PPPoE1) receive PADT
10/27/2014 22:45:14 If(PPPoE1) send PADI
10/27/2014 22:45:14 If(PPPoE1) stop
10/27/2014 22:45:12 If(PPPoE1) stop PPP
10/27/2014 22:42:20 If(PPPoE1) PPP connection ok !
10/27/2014 22:42:19 If(PPPoE1) get secondary DNS IP:195.50.140.248
10/27/2014 22:42:19 If(PPPoE1) get primary DNS IP:195.50.140.118
10/27/2014 22:42:19 If(PPPoE1) get IP:188.100.82.209
10/27/2014 22:42:19 If(PPPoE1) start PPP
10/27/2014 22:42:19 If(PPPoE1) receive PADS
10/27/2014 22:42:19 If(PPPoE1) send PADR
10/27/2014 22:42:19 If(PPPoE1) receive PADO
10/27/2014 22:42:19 If(PPPoE1) send PADI
10/27/2014 22:42:15 If(PPPoE1) receive PADT
10/27/2014 22:42:14 If(PPPoE1) send PADI
10/27/2014 22:42:14 If(PPPoE1) Dial PPP
10/27/2014 22:42:13 If(PPPoE1) stop
10/27/2014 22:42:11 If(PPPoE1) stop PPP
10/27/2014 22:40:50 If(PPPoE1) PPP connection ok !
10/27/2014 22:40:49 If(PPPoE1) get secondary DNS IP:195.50.140.248
10/27/2014 22:40:49 If(PPPoE1) get primary DNS IP:195.50.140.118
10/27/2014 22:40:49 If(PPPoE1) get IP:188.100.186.23
10/27/2014 22:40:49 If(PPPoE1) start PPP
10/27/2014 22:40:49 If(PPPoE1) receive PADS
10/27/2014 22:40:48 If(PPPoE1) send PADR
10/27/2014 22:40:48 If(PPPoE1) receive PADO
10/27/2014 22:40:48 If(PPPoE1) send PADI
10/27/2014 22:40:44 If(PPPoE1) receive PADT
10/27/2014 22:40:43 If(PPPoE1) send PADI
10/27/2014 22:40:43 If(PPPoE1) stop
10/27/2014 22:40:41 If(PPPoE1) stop PPP
10/27/2014 22:38:18 If(PPPoE1) PPP connection ok !
10/27/2014 22:38:17 If(PPPoE1) get secondary DNS IP:195.50.140.248
10/27/2014 22:38:17 If(PPPoE1) get primary DNS IP:195.50.140.118
10/27/2014 22:38:17 If(PPPoE1) get IP:188.100.186.23
10/27/2014 22:38:17 If(PPPoE1) start PPP
10/27/2014 22:38:17 If(PPPoE1) receive PADS
10/27/2014 22:38:17 If(PPPoE1) send PADR
10/27/2014 22:38:17 If(PPPoE1) receive PADO
10/27/2014 22:38:17 If(PPPoE1) send PADI
10/27/2014 22:38:12 If(PPPoE1) receive PADT
10/27/2014 22:38:12 If(PPPoE1) send PADI
10/27/2014 22:38:12 If(PPPoE1) Dial PPP
10/27/2014 22:38:12 If(PPPoE1) stop
10/27/2014 22:38:10 If(PPPoE1) stop PPP
10/27/2014 22:33:28 Wireless 24:EC:99:DD:68:1C released
10/27/2014 22:31:10 **UDP Flood Stop** (from PPPoE1 Outbound)
10/27/2014 22:31:05 **UDP flood** 192.168.2.103, 53534->> 157.56.144.215, 3544 (from PPPoE1 Outbound)
10/27/2014 22:30:57 **UDP flood** 192.168.2.103, 53534->> 157.56.144.215, 3544 (from PPPoE1 Outbound)
10/27/2014 22:30:53 **UDP flood** 192.168.2.103, 53534->> 157.56.144.215, 3544 (from PPPoE1 Outbound)
10/27/2014 22:30:51 **UDP flood** 192.168.2.103, 63883->> 208.78.164.11, 27017 (from PPPoE1 Outbound)
10/27/2014 22:30:51 **UDP flood** 192.168.2.103, 53534->> 157.56.144.215, 3544 (from PPPoE1 Outbound)
10/27/2014 22:30:51 **UDP flood** 192.168.2.103, 63883->> 208.78.164.9, 27018 (from PPPoE1 Outbound)
10/27/2014 22:30:51 **UDP flood** 192.168.2.103, 63883->> 208.78.164.12, 27019 (from PPPoE1 Outbound)
10/27/2014 22:30:51 **UDP flood** 192.168.2.103, 63883->> 208.78.164.10, 27019 (from PPPoE1 Outbound)
10/27/2014 22:30:51 **UDP flood** 192.168.2.103, 63883->> 208.78.164.13, 27018 (from PPPoE1 Outbound)
10/27/2014 22:30:51 **UDP flood** 192.168.2.103, 63883->> 208.78.164.14, 27019 (from PPPoE1 Outbound)
10/27/2014 22:30:51 **UDP flood** 192.168.2.103, 63883->> 146.66.156.10, 27020 (from PPPoE1 Outbound)
10/27/2014 22:30:51 **UDP flood** 192.168.2.103, 63883->> 146.66.156.9, 27018 (from PPPoE1 Outbound)
10/27/2014 22:30:51 **UDP flood** 192.168.2.103, 63883->> 146.66.156.11, 27020 (from PPPoE1 Outbound)
10/27/2014 22:30:51 **UDP flood** 192.168.2.103, 63883->> 146.66.152.11, 27019 (from PPPoE1 Outbound)
10/27/2014 22:30:51 **UDP flood** 192.168.2.103, 63883->> 146.66.155.8, 27018 (from PPPoE1 Outbound)
10/27/2014 22:30:51 **UDP flood** 192.168.2.103, 63883->> 146.66.155.9, 27019 (from PPPoE1 Outbound)
10/27/2014 22:30:51 **UDP flood** 192.168.2.103, 63883->> 146.66.152.10, 27018 (from PPPoE1 Outbound)
10/27/2014 22:30:50 **UDP flood** 192.168.2.103, 54246->> 54.72.205.147, 80 (from PPPoE1 Outbound)
10/27/2014 22:30:40 **UDP flood** 192.168.2.103, 56807->> 46.105.112.65, 17385 (from PPPoE1 Outbound)
10/27/2014 22:30:30 192.168.2.103 login success
10/27/2014 22:30:30 User from 192.168.2.103 timed out
10/27/2014 22:30:20 **UDP Flood (per Min)** 192.168.2.103, 54246->> 54.72.205.147, 80 (from PPPoE1 Outbound)
10/27/2014 22:30:20 **UDP flood** 192.168.2.103, 54246->> 54.72.205.147, 80 (from PPPoE1 Outbound)
10/27/2014 22:30:09 **UDP Flood (per Min)** 192.168.2.103, 57722->> 93.93.65.143, 27017 (from PPPoE1 Outbound)
10/27/2014 22:30:09 **UDP flood** 192.168.2.103, 57722->> 93.93.65.143, 27017 (from PPPoE1 Outbound)
10/27/2014 22:30:08 **UDP Flood (per Min)** 192.168.2.103, 57719->> 108.61.112.166, 27017 (from PPPoE1 Outbound)
10/27/2014 22:28:13 sending ACK to 192.168.2.100
10/27/2014 22:11:20 sending ACK to 192.168.2.105
10/27/2014 22:10:08 Wireless 24:EC:99:DD:68:1C released
10/27/2014 21:15:42 sending ACK to 192.168.2.100
10/27/2014 21:14:37 sending ACK to 192.168.2.100
10/27/2014 21:10:28 **TCP FIN Scan** 192.168.2.105, 55034->> 74.125.136.106, 80 (from PPPoE1 Outbound)
10/27/2014 21:10:28 **TCP FIN Scan** 192.168.2.105, 55070->> 173.194.113.152, 443 (from PPPoE1 Outbound)
10/27/2014 21:10:28 **TCP FIN Scan** 192.168.2.105, 55053->> 173.194.113.137, 80 (from PPPoE1 Outbound)
10/27/2014 21:10:28 **TCP FIN Scan** 192.168.2.105, 55060->> 173.194.113.135, 80 (from PPPoE1 Outbound)
10/27/2014 21:10:28 **TCP FIN Scan** 192.168.2.105, 55105->> 74.125.136.155, 80 (from PPPoE1 Outbound)
10/27/2014 21:10:28 **TCP FIN Scan** 192.168.2.105, 55123->> 205.204.116.40, 80 (from PPPoE1 Outbound)
10/27/2014 21:10:28 **TCP FIN Scan** 192.168.2.105, 55103->> 88.221.93.39, 80 (from PPPoE1 Outbound)
10/27/2014 21:10:28 **TCP FIN Scan** 192.168.2.105, 55098->> 88.221.92.247, 80 (from PPPoE1 Outbound)
10/27/2014 21:10:28 **TCP FIN Scan** 192.168.2.105, 55089->> 195.59.70.240, 80 (from PPPoE1 Outbound)
10/27/2014 21:10:28 **TCP FIN Scan** 192.168.2.105, 55116->> 205.204.116.27, 80 (from PPPoE1 Outbound)
10/27/2014 21:10:28 **TCP FIN Scan** 192.168.2.105, 55132->> 88.221.92.151, 80 (from PPPoE1 Outbound)
10/27/2014 21:10:28 **TCP FIN Scan** 192.168.2.105, 55090->> 88.221.93.63, 80 (from PPPoE1 Outbound)
10/27/2014 21:10:28 **TCP FIN Scan** 192.168.2.105, 55131->> 173.194.113.136, 80 (from PPPoE1 Outbound)
10/27/2014 21:10:28 **TCP FIN Scan** 192.168.2.105, 55106->> 88.221.93.56, 80 (from PPPoE1 Outbound)
10/27/2014 21:10:28 **TCP FIN Scan** 192.168.2.105, 55100->> 195.59.70.250, 80 (from PPPoE1 Outbound)
10/27/2014 21:10:28 **TCP FIN Scan** 192.168.2.105, 55085->> 88.221.92.255, 80 (from PPPoE1 Outbound)
10/27/2014 21:10:28 **TCP FIN Scan** 192.168.2.105, 55077->> 173.194.113.139, 80 (from PPPoE1 Outbound)
10/27/2014 20:47:09 sending ACK to 192.168.2.100
10/27/2014 20:10:08 Wireless 24:EC:99:DD:68:1C released
10/27/2014 19:58:56 192.168.2.103 login success
10/27/2014 19:58:46 192.168.2.103 login fail
10/27/2014 19:58:36 User from 192.168.2.103 timed out
10/27/2014 19:53:26 sending ACK to 192.168.2.100
10/27/2014 19:53:22 sending ACK to 192.168.2.100
10/27/2014 19:46:40 sending ACK to 192.168.2.100
10/27/2014 19:42:36 sending ACK to 192.168.2.104
10/27/2014 19:31:23 sending ACK to 192.168.2.102
10/27/2014 19:28:28 192.168.2.103 login success
10/27/2014 19:27:58 NTP Date/Time updated.
08/23/2013 00:00:30 Get system time from NTP server:129.70.132.35.
08/23/2013 00:00:27 sending ACK to 192.168.2.105
08/23/2013 00:00:26 If(PPPoE1) PPP connection ok !
08/23/2013 00:00:25 If(PPPoE1) get secondary DNS IP:195.50.140.248
08/23/2013 00:00:25 If(PPPoE1) get primary DNS IP:195.50.140.118
08/23/2013 00:00:25 If(PPPoE1) get IP:188.101.69.58
08/23/2013 00:00:25 If(PPPoE1) start PPP
08/23/2013 00:00:25 If(PPPoE1) receive PADS
08/23/2013 00:00:25 If(PPPoE1) send PADR
08/23/2013 00:00:25 If(PPPoE1) receive PADO
08/23/2013 00:00:25 If(PPPoE1) send PADI
08/23/2013 00:00:24 ADSL Media Up !
08/23/2013 00:00:00 sending ACK to 192.168.2.103
weiß jemand einen Rat? wenn noch weitere Informationen gebraucht werden ,einfach melden.
