No internet - Modem Status In Process
Jrod747
I’ve had working internet for the last few months. On Thursday my Landlord had a technician “reset the power” in the basement and after it came back on 10-15 minutes later, the internet has stopped working. I’ve been without internet since and have tried resetting and everything. The landlord insists that it has nothing to do with them, but I suspect that they messed something up with the internet cables in the basement. Does anyone know a fix for the Modem Status : in process or do I need an appointment with a technician?
Andre
Hey Jrod747,
are you using a dsl or cable contract?
Which exact routermodel are you using?
A lot of issues can be solved by a reset to factorydefaults.
Therefore i need to know the exact model.
Best regards,
Andre
Jrod747
Hello Andre,
The model is CH7466CE. I’ve done a factory reset and multiple normal resets/ unplugging cables. I believe I have a DSL contract as it’s only for internet.
Wallace
Hi Jrod747,
Please send me your customer data (name, date of birth, address, customer number) in a private message, then I will take a look at the line and if necessary arrange for a technician to be called in.
Briefly let me know that you have sent the data.
Regards
Wallace
