am 01.08.2019 22:30 - zuletzt bearbeitet am 02.08.2019 08:26 von Thomas
I have an internet connection for 1.5 years. I was supposed to get 100 Mbps. I am not even getting 5 Mbps most of the times and also I see the connection gets disconnected frequently (its big problem when you download some file and due to disconnection it has to start again).
I complained about it many times but there was no use. Every time when I complain about my internet speed you people made it even more worse for me like changing the meinkabel to DSL and again DSL to meinkabel but there was no result.
I was given many appointments. Which were canceled from vodafone people at the last moment.
Normally If there was an appointment and customers were not there in the house you people charge around 50 euros. Does it not apply to you people, cancelling the appointments at last moment.
I immediately want a solution either you fix the speed or please cancel the contract immediately.
Thanks
Dinesh
Edit: @Dinesh moved in to the right board.
am 16.08.2019 08:42
Hello Dinesh,
the technician has to go to the apartment because of the house wiring. Here it is so that not each dwelling has its own line, but the sockets are connected in series. Therefore an access is necessary, so that the line can be suppressed.
Can you please take care of this?
Best regards
Moni
am 23.08.2019 17:29
Hello Moni,
I tried several times ringing their bell. They are not at all responding. It's getting very irritating. I have to spend a lot of time knocking them and there is no use. if you cant solve the problem immediately, Cancel the contract immediately.
Asking me to get in touch with my neighbors is complete nonsense. But even I tried, but it didn't work. Please solve the problem immediately or Cancel the contract immediately.
Thanks
Dinesh
am 23.08.2019 17:37
Hello Wallace,
I tried several times ringing their bell. They are not at all responding. It's getting very irritating. I have to spend a lot of time knocking them and there is no use. If you cant solve the problem immediately, Cancel the contract immediately.
Asking me to get in touch with my neighbors is complete nonsense. But even I tried, but it didn't work. Please solve the problem immediately or Cancel the contract immediately. Don't harass your customers by doing anything from a year. My hands are paining in writing tens of emails to you
Thanks
Dinesh
am 25.08.2019 21:38
Hello Dinesh
just stick a note on the door. Maybe that's how the contact comes about.
Regards
Jens
am 29.08.2019 13:47
Hallo jens,
I did that also, but still, there was no response from 4 days.
And now Jens Don't say useless ideas. It's not my problem, to run around people, ringing their bells, sticking notes and all. I am fed off doing all the things said by you.
Have some common sense and responsibility for the money you are charging monthly and fix the issue or if you are capable of nothing just cancel the contract. The problem is not fixed from 1.5 years now. Every time saying some nonsense stories and you people are escaping from it.
Thanks
Dinesh
am 29.08.2019 21:56
Hello Dinesh,
thank you for your commitment. It was not useless. But positiv for now is, that the cable-router works without the affected frequencies. 🙂
Did you have any problems now?
Regards
Jens
am 01.09.2019 14:22
Hello Jens,
I am fed off hearing works without the affected frequencies stories. I heard it many times but of no use.
See the screenshots I attached at different times.
You have to check the whole day, as there is so much variance in the speed and so the connection itself. There were many disruptions
please don't tell such stories and fix with actual solution. I am paying for 100 MBPS I am not even getting 20mbps. Have some common sense and don't make to write so many emails or complaints. I am sick of writing 50+ emails by now.
Thanks
Dinesh
am 02.09.2019 16:52
Hello, Dinesh,
I'd be happy to send another technician. But I can't promise at this point that he can do much without access to the other apartment. But it would be worth a try. Would that be okay? Maybe the technician has the possibility to sound the neighbour again or leave her a card if she doesn't react to your contact attempts.
Best regards
Moni
am 02.09.2019 23:00
Hi Moni,
Thanks a lot for the sensible reply. You can do that. For me any time is fine. Let me know when the technician comes.
Thanks
Dinesh
am 04.09.2019 07:52
Hello, Dinesh,
contact was attempted via the property management. We do not send a technician who distributes notes on site. The access to the neighbour is necessary.
Best regards Fred
