Internet disconnection
Moosburg
Internet connection is frequently disconnected.Everytime I have to connect it again.For past two three days when the connection Is lost I have to remove the plug and plug it again,even though after few minutes connection is lost
6 Antworten 6
Norman
Community Manager
Community Manager
Hi Moosburg,
i'm sorry for that issue. 😞
I have a few questions:
Does the problem still exist?
Which router/modem do you use?
What is the logfile saying?
Did you tried a full factory reset?
Best regads,
Norman
Hello
Thank you for your reply !.
Please find my answer for your query.
-Yes it still exists. On an average thrice per hour I have to restart the modem.
Which router / modem do you use?
-The modem name is Sagemcom (Model FAST 5460)
-Automatically the internet connections will loose. Then one of the light (from 4 light)  goes off, once I restart the modem, the connection will be up.
Did you try a full factory reset?
-Till now I didn’t do that. I have a doubt whether the log in password will be changed.
Wallace
Hi Moosburg,
Please send me your customer data (name, birthday, address, customer number) in a private message, then I look at the line.
Contact me briefly here when you have sent the data.
Regards
Wallace
Hello Wallace
I have shared my information to you.
Manu
Hi Moosburg,
thanks for the data. The signal values are very badly adjusted.  A technician is absolutely necessary on site. Can you guarantee access to the house system?
Will you please send me a phone number where we can reach you by PN for an appointment?
Best Regards, Manu
Hi Moosburg,
the technician is informed. He will call you to arrange an appointment.
Please keep us informed.
Kind regards
