am 09.11.2020 20:48
Hello,
The internet connection in my house breaks 2 to 3times a day from last 2weeks. After the internet connection breaks, I need to restart my router(unplug power supply, wait for 10seconds and then connect power supply) - then the connection becomes normal. This is happening from last 2weeks everyday atleast 2times.
My plan : Red Internet & Phone 250 Cable
Regards,
Arun
am 16.11.2020 09:20
Hello Arun2,
which device do you have from us? In which federal state do you live exactly? Is only the WiFi connection affected or also the Ethernet connection?
Greetings Moni
am 16.11.2020 20:38
Hello Moni,
Device : WLAN-Router Vodafone-Station dauerhaft kostenlos
Federal State : Koblenz, Rhineland-Pfalz
Both WiFi and ethernet connection are affected.
Regards,
Arun
am 19.11.2020 15:33
Hello Arun2,
gladly I can have a look at the line. Please send me a PN with your customer data (name, address, customer number and date of birth).
Then please contact me again here when you have sent me the data.
Best regards
Moni
am 19.11.2020 23:08 - zuletzt bearbeitet am 24.11.2020 13:27 von Tobias
Hello,
Here are the requested details :
Regards,
Arun
am 24.11.2020 13:28
am 27.11.2020 08:54
Hello Arun2,
the signal looks good so far but there are some timeouts. Did you already replace the coaxial cable? Does the connection via ethernet cable get lost as well? Are both Wifi networks affected? What happens exactly, do the devices loose their connection and can't be connected with the router unless you make a reset?
Kind regards,
am 29.11.2020 16:45
Hello Claudia,
I have not replaced any cable.
The connection is lost in both wifi and ethernet. Devices connected to internet(laptop, mobiles, TV) indicate that internet is not available("Connected but no internet"). But the router has the internet lamp ON(indicating internet is present even though in reality internet is not present). I need to remove the power supply to router, wait 10s and then reconnect the power supply(basically I am restarting the router)). After few seconds the devices get reconnected and the internet is back. This happens 2-3times a day.
Regards,
Arun
am 03.12.2020 14:52
Hallo Arun2,
a different coaxial cable and a reset to the delivery condition might help. If the problems persist, please send some examples when the ethernet connection drops, so we can check the line again.
Kind regards,
