High ping every night
Andrielix
High ping every night since January...
I cannot even play any game from my wired PC or wifi...
MY ping is on average 200 and can go up to 400 at night!!!!!
Edit: @Andrielix moved to the right board.
Hello Andrielix,
please make a Pingplotter to the game servers and use a direct ethernet connection. Do you only habe problems with online games or are other services like streams affected as well? Which router do you use? Does the ping get better when you reboot the modem?
Kind regards,
