Hilfsangebote außerhalb der Community
  • Jetzt mit Tobi chatten Chat Jetzt mit TOBi chatten
  • Nutze unsere Hile bei Störung. Störung? Nutz unsere Hilfe bei Störung!
  • Entedecke unsere digitalen Lösungen und nutze sie Mehr? Entdecke unsere digitalen Lösungen und nutz sie!
Extremely slow upload speed / Cable 100 - [English]
eduardonunes
I've been experiencing extremely slow upload speed recently. The download is very fast, almost all speed test apps show download speed between 80 to 100mbits/s. However, the upload speed floats between 1 to 2mbits/s. When I'm really lucky I get 3mbits/s but it just loads for a few seconds.
I, unfortunately, do not speak German, so it's really hard to interact with support.
I had a similar issue in the past, it was a problem in my region that got fixed after contacting you, folks (the address now is different though)
https://forum.vodafone.de/t5/Archiv-St%C3%B6rungsmeldungen/Extremely-slow-upload-speed-Cable-100-Eng...
Kind regards,
ERFD
Hello melnikaite,
there has been no response here since December 2020. Please open a separate post and answer these questions there.
Best regards Fred
6 Antworten 6
pRo-Marco
Hi eduardonunes,
I'd like to prove your connection. Please send me your name, address and customer number by PN. Please also let me know here if you have sent the message.
Kind regards
Martin59
Hello eduardonunes,
Is the malfunction permanent or does it only occur at certain times?
Best regards, Martin
Hi Martin,
It never reaches 10mbit/s (upload). The speed gets slightly better during the evening or very early in the morning. Luckily at the moment, the Vodafone speed test says 7Mbit/s.
Kind regards,
Hello eduardonunes,
please make a speedtest via ethernet connection and send the result with a time stamp. We can check the line with that example.
Kind regards,
I have the same issue
4 out of 50Mbit/s via cable directly connected to new FRITZ!Box 6591 from first day of connecting
However router itself conncted to Vodafone network on a good speed ↓ 1150 Mbit/s↑ 56,7 Mbit/s
Berlin 10829
ERFD
Hello melnikaite,
Best regards Fred
