[English] Internet Kabel breaks every morning
valentinm
  • Which contract do you have? Red Internet & Phone 400 Cable
  • Which modem / router do you use? Vodafone station
  • Do you use a loaner device from us or do you have your own device? Loan device
  • What is the error?
Every morning, between 10am and 11am (Today it was exactly 10.30) my internet completely stop (WLAN and LAN) for 10-15min. I am still technically connected to the box, but there is just no internet at all.
There is no change in the led on the cable box during the interruption. If I try to restart the box nothing change, I still have to wait some minutes.
I have added below the event on the box, maybe that can help.
I have also observed (randomly so no screenshot available at hand) that I sometime have a very very high ping (around 6000).
I tried yesterday to factory reset the box, but still this morning the problem arised.
It does not seem that in my building other Vodafone users are experiencing the same issue.
  • How is your terminal connected to the modem? WLAN & LAN
  • Which browser do you usually use? Chrome
  • Which operating system do you have on your computer? Mac and android
  • Start and period of the disturbance Since the beginning of January, every morning
  • Upload a screenshot of the signal values. You can find this in the user interface of your cable router
    via 192.168.0.1 or via 192.168.178.1 on the Fritzbox.
  • What measures were carried out by the fault hotline (available at 0800-5266625)? None
  • In which state do you live? Berlin
Here is the event log of the Vodafone station:
01/25/2021
10:41:54
client steer attempt: success = SUCCESS, STA MAC = 72: 9B: 0A: D4: ED: 12, AP before = 94: 8F: CF: 94: C8: 37, AP after = 94: 8F: CF: 94: C8: 38, trigger = proactive, type = BTM, duration = 5, time = Mon Jan 25 10:41:49 2021
WIRELESS INTERNET ACCESS
01/25/2021
10:41:53
DISASSOC - MAC = 72: 9b: 0a: d4: ed: 12, Reason = 34; WG-MAC = 94: 8F: CF: 94: C8: 37; IF = wlan0_0
01/25/2021
10:41:50
REASON-CODE-DESCR = PREV_AUTH_NOT_VALID; REASON-CODE = 2; WG-MAC = 94: 8F: CF: 94: C8: 37; STA-MAC = 72: 9b: 0a: d4: ed: 12; IF = wlan0_0; SSID = Vodafone-1CCC;ConnectionState = forcedDisassociatedAuth; WirelessMode = 802.11n; LastTxPhyRate = 52Mbps; LastRxPhyRate = 130Mbps; MaxSupportedRate: 144Mbps; EncryptMode = AES; AuthMode = WpaPsk; RSSI = -49dBm; Channel = 2462MHz; Radio = 2.4G; Bandwidth = 20M; TxFailPkts = 0; RetransPkts = 226
01/25/2021
10:41:50
WG-MAC = 94: 8F: CF: 94: C8: 38; STA-MAC = 72: 9b: 0a: d4: ed: 12; IF = wlan1_0; SSID = Vodafone-1CCC; ConnectionState = connected; WirelessMode = 802.11ac; LastTxPhyRate = 351Mbps; LastRxPhyRate = 6Mbps;MaxSupportedRate: 866Mbps; EncryptMode = AES; AuthMode = WpaPsk; RSSI = -54dBm; Channel = 5500MHz; Radio = 5G; Bandwidth = 80M; TxFailPkts = 0; RetransPkts = 0
01/25/2021
10:41:50
MAC 72: 9b: 0a: d4: ed: 12 associated to Vodafone-1CCC; WG-MAC = 94: 8F: CF: 94: C8: 38; IF = wlan1_0
01/25/2021
10:41:50
MAC 72: 9b: 0a: d4: ed: 12 authentication with Vodafone-1CCC; WG-MAC = 94: 8F: CF: 94: C8: 38; IF = wlan1_0
01/25/2021
10:41:50
BSS-TRANS-MGMT-RESP 72: 9b: 0a: d4: ed: 12 0 1611567710
01/25/2021
10:41:50
BSS-TM-RESP 72: 9b: 0a: d4: ed: 12 status_code = 0 bss_termination_delay = 0 target_bssid = 94: 8f: cf: 94: c8: 38
01/25/2021
10:41:32
WG-MAC = 94: 8F: CF: 94: C8: 37; STA-MAC = 72: 9b: 0a: d4: ed: 12; IF = wlan0_0; SSID = Vodafone-1CCC; ConnectionState = connected; WirelessMode = 802.11n; LastTxPhyRate = 26Mbps; LastRxPhyRate = 6Mbps; MaxSupportedRate: 144Mbps; EncryptMode = AES; AuthMode = WpaPsk; RSSI = -48dBm; Channel = 2462MHz;Radio = 2.4G; Bandwidth = 20M; TxFailPkts = 0; RetransPkts = 0
01/25/2021
10:41:32
MAC 72: 9b: 0a: d4: ed: 12 associated to Vodafone-1CCC; WG-MAC = 94: 8F: CF: 94: C8: 37; IF = wlan0_0
01/25/2021
10:41:32
MAC 72: 9b: 0a: d4: ed: 12 authentication with Vodafone-1CCC; WG-MAC = 94: 8F: CF: 94: C8: 37; IF = wlan0_0
01/25/2021
10:36:41
REASON-CODE-DESCR = DISASSOC_STA_HAS_LEFT; REASON CODE = 8; WG-MAC = 94: 8F: CF: 94: C8: 38; STA-MAC = f8: ff: c2: 3d: 85: 04; IF = wlan1_0;SSID = Vodafone-1CCC; ConnectionState = clientDisassociated; WirelessMode = 802.11ac; LastTxPhyRate = 585Mbps; LastRxPhyRate = 0Mbps; MaxSupportedRate: 866Mbps; EncryptMode = AES; AuthMode = WpaPsk; RSSI = -62dBm; Channel = 5500MHz; Radio = 5G; Bandwidth = 80M; TxFailPkts = 0; RetransPkts = 53665
01/25/2021
10:36:41
REASON-CODE-DESCR = DISASSOC_STA_HAS_LEFT; REASON CODE = 8; WG-MAC = 94: 8F: CF: 94: C8: 38; STA-MAC = f8: ff: c2: 3d: 85: 04; IF = wlan1_0; SSID = Vodafone-1CCC; ConnectionState = other_deassociate;WirelessMode = 802.11ac; LastTxPhyRate = 585Mbps; LastRxPhyRate = 0Mbps; MaxSupportedRate: 866Mbps; EncryptMode = AES; AuthMode = WpaPsk; RSSI = -62dBm; Channel = 5500MHz; Radio = 5G; Bandwidth = 80M; TxFailPkts = 0; RetransPkts = 53665
01/25/2021
10:36:41
DISASSOC - MAC = f8: ff: c2: 3d: 85: 04, Reason = 8; WG-MAC = 94: 8F: CF: 94: C8: 38; IF = wlan1_0
01/25/2021
10:36:41
DISASSOC - MAC = f8: ff: c2: 3d: 85: 04, Reason = 34; WG-MAC = 94: 8F: CF: 94: C8: 38; IF = wlan1_0
01/25/2021
10:32:27
DISASSOC - MAC = 72: 9b: 0a: d4: ed: 12, Reason = 34; WG-MAC = 94: 8F: CF: 94: C8: 38; IF = wlan1_0
01/25/2021
10:32:27
DEAUTH - MAC = 72: 9b: 0a: d4: ed: 12, Reason = 3; WG-MAC = 94: 8F: CF: 94: C8: 38; IF = wlan1_0
01/25/2021
10:32:27
REASON-CODE-DESCR = DEAUTH_LEAVING; REASON-CODE = 3; WG-MAC = 94: 8F: CF: 94: C8: 38; STA-MAC = 72: 9b: 0a: d4: ed: 12; IF = wlan1_0; SSID = Vodafone-1CCC; ConnectionState = clientDisassociated; WirelessMode = 802.11ac;LastTxPhyRate = 702Mbps; LastRxPhyRate = 0Mbps; MaxSupportedRate: 866Mbps; EncryptMode = AES; AuthMode = WpaPsk; RSSI = -52dBm; Channel = 5500MHz; Radio = 5G; Bandwidth = 80M; TxFailPkts = 0; RetransPkts = 51756
21 Antworten 21
@Claudia @ERFD @Wallace
The new equipement was installed this weekend, after a few days of test well the problem is still there. The connection is actully worst than before... Yesterday evening it was barely impossible to have a zoom meeting.
Today at 10.43 again the connection stopped. I have attache the log
Also I find it really weird that every time the connection stop it also break the 4G of my phone during the time of the outage (which is also vodafone). Coud the two be linked? I have attached pictures the speedtest of my phone during the outage
Would it be possible for you to run tests again because CLEARLY something is wrong here and it impacts my work a lot
Here is the log during the outage:
Datum	Uhrzeit	Details
02/09/2021	10:45:54	REASON-CODE-DESCR=DISASSOC_STA_HAS_LEFT;REASON-CODE=8; WG-MAC=C8:52:61:BF:31:CC; STA-MAC=f8:ff:c2:3d:85:04; IF=wlan1_0; SSID=Vodafone-F86E; ConnectionState=other_deassociate; WirelessMode=802.11ac; LastTxPhyRate=866Mbps; LastRxPhyRate=0Mbps; MaxSupportedRate:866Mbps; EncryptMode=AES; AuthMode=WpaPsk; RSSI=-50dBm; Channel=5320MHz; Radio=5G; Bandwidth=80M; TxFailPkts=0; RetransPkts=10263
02/09/2021	10:45:54	DISASSOC - MAC=f8:ff:c2:3d:85:04, Reason=34; WG-MAC=C8:52:61:BF:31:CC; IF=wlan1_0
02/09/2021	10:45:54	REASON-CODE-DESCR=DISASSOC_STA_HAS_LEFT;REASON-CODE=8; WG-MAC=C8:52:61:BF:31:CC; STA-MAC=f8:ff:c2:3d:85:04; IF=wlan1_0; SSID=Vodafone-F86E; ConnectionState=clientDisassociated; WirelessMode=802.11ac; LastTxPhyRate=866Mbps; LastRxPhyRate=0Mbps; MaxSupportedRate:866Mbps; EncryptMode=AES; AuthMode=WpaPsk; RSSI=-50dBm; Channel=5320MHz; Radio=5G; Bandwidth=80M; TxFailPkts=0; RetransPkts=10263
02/09/2021	10:45:54	DISASSOC - MAC=f8:ff:c2:3d:85:04, Reason=8; WG-MAC=C8:52:61:BF:31:CC; IF=wlan1_0
02/09/2021	10:43:20	DEAUTH - MAC=6a:59:1f:c5:24:e4, Reason=3; WG-MAC=C8:52:61:BF:31:CC; IF=wlan1_0
02/09/2021	10:43:20	REASON-CODE-DESCR=DEAUTH_LEAVING;REASON-CODE=3; WG-MAC=C8:52:61:BF:31:CC; STA-MAC=6a:59:1f:c5:24:e4; IF=wlan1_0; SSID=Vodafone-F86E; ConnectionState=clientDisassociated; WirelessMode=802.11ac; LastTxPhyRate=526Mbps; LastRxPhyRate=117Mbps; MaxSupportedRate:866Mbps; EncryptMode=AES; AuthMode=WpaPsk; RSSI=-50dBm; Channel=5320MHz; Radio=5G; Bandwidth=80M; TxFailPkts=0; RetransPkts=23050
02/09/2021	10:43:20	DISASSOC - MAC=6a:59:1f:c5:24:e4, Reason=34; WG-MAC=C8:52:61:BF:31:CC; IF=wlan1_0
Hello valentinm,
the mobile connection doesn't interfere with the cable connection. I saw a technician shall visit next monday, the colleague will have a look at that.
Kind regards,
Hi here,
Reporting back on the issue, even tho I did receive an sms indicating that the problem is a grid problem and will be fixed in a few month I do believe that something can be done in the mean time.
I have attached the ping plotter graph, it might help see more what is happening: crazy packet loss 🙂
Do you think that going with a HomeBox Fritz! Box 6591 would fix or help with this issue?
Thank
ERFD
Hello valentinm,
unfortunately the test says nothing. Why do you do a latency test to the manufacturer of the test? The server is in the States and automatically bad. Since the latency is much higher until then. +-100 ms. The values of your box are not visible at all. Please try www.google.de or a comparable site. Please also send the whole excerpt.
Best regards Fred
valentinm
Got it, here is a new test, with screenshot of the issue + two files:
- the  excerpt at the moment of the issue
- full file for a couple of days
You can find them in this drive (was not allowed to upload files with this extension) here:  https://drive.google.com/drive/folders/1TgyBUToj-JdN9rRAkw9-jiVaRXMwu8jK?usp=sharing
I also created a shared page with the report here:  https://share.pingplotter.com/SCRDGyBkXVV
Cheers
Valentine
Wallace
Hi Valentin,
at what time do the problems start? We currently have too high a load on the upstreams and I would like to see if there is a connection.
Regards
Wallace
Hi @Wallace
It started at least more than a month ago I would say
Jana478
Administrator:in
Administrator:in
Hi valentinm,
The colleague wanted to know, do you have the disturbances all day or only at certain times? For example, only in the evening or only early in the morning?
Kind Regards
Jana
The breaking is getting a bit better, it was always between 10am and 11am and sometimes in the evening.
But I still have constantly 1mbits upload vs 25mbits I should be getting
Jana478
Administrator:in
Administrator:in
Hi valentinm,
Here in the region, we are experiencing capacity utilisation problems during peak hours, which is causing bandwidth to plummet in some cases. Our technicians are currently working on network expansion to relieve the strain on the line. A ticket for you has already been created.
Unfortunately, I can't tell you when this will be completed.
Kind regards
Jana
