am
16.06.2018
15:18
- zuletzt bearbeitet am
16.06.2018
15:52
von
Lars
My cable modem is misbehaving in a few different ways:
- Not letting devices connect, especially after running for a few days
- Not handing out IP-addresses to devices that connect
- Not routing packets to all IP-addresses. For example, pinging 8.8.8.8 or 1.1.1.1 fails sometimes
I've tried the following, but without it helping:
- Restarting the router
- Resetting the router
- Trying to connect using 5 different devices
- Opened a support ticket, with Vodafone, ***
I've been trying to fix this for the past 6 days, with no success, and since my vacation is over now, I really need my internet connection to be functional so that I can work.
Edit: @robertfoss Ticket ID deleted
am 22.06.2018 21:17
I don't know anything about the signal quality.
I do know that the modem is behaving really badly, and stops allowing devices connect after a while, and requires a hard restart per day. This hasn't been getting better since I started talkinig to support.
Can you please send a new modem? 2 weeks of only sometimes working internet is enough.
am 26.06.2018 08:46
Hello robertfoss,
I can see that the signal quality is poor again, so I would like to hire a technician.
When can you be contacted?
Regards
Jens
am 26.06.2018 09:39
I work from home, so any weekday would work. Ideally not between 14-15:00 since I have meetings then.
Could you make sure that the technician brings a replacement modem?
am 28.06.2018 09:53
Hello robertfoss,
i instruct a technician. Let us know, what they do.
Regards
Jens
09.07.2018 15:18 - bearbeitet 09.07.2018 15:19
A technician came by, and replaced the modem. The internet connection seemed to work for about a few hours, and then went down again.
The connection has been going up and down since, and will typically stay up for a few hours and the go down for 24 hours or so.
So I would definitely say that my issue has not been solved.
Are other tenants in my building having the same issue? Or is it just me?
I think there are serious signal issues in my apartment, and possibly this entire building.
am 10.07.2018 13:50
Hello robertfoss,
i can see the issue and a technician have to look again. Is it ok for you?
And i think also, that is something wrong in the building.
Reards
Jens
am 10.07.2018 14:18
Sure, send one over.
What happens if the signal quality is ok when the technician is over?
am 12.07.2018 08:24
Hello robertfoss,
at the moment we are waiting with the technician, because the connection looks good again since one day.
If it worsens, please contact us here.
Regards
Jens
