Bandwidth very low
JoaoRodrigues
I have several times per day my connection going down on my router. WIFI seems ok, because I have normally over 60/70 Mgb, but on cable, it is crashing down to 10/15Mgb, and sometimes the router is loosing all signal. I need to restart it, and then it goes again on low speed...
What can I do?
Vodafone Support was not able to give me technical support in English...
Thanks
Joao
EDIT: @JoaoRodrigues moves to cable board
ERFD
Hello, Joao Rodrigues,
there is no further order open. With the last order of 11.08.2018 a component in the house was replaced.
Can we finish your contribution with your feedback?
Greeting Fred
22 Antworten 22
Wallace
Hi JoaoRodrigues,
The connection only breaks down via LAN cable? Have you already tested another cable?
Regards
Wallace
Hello Wallace
I did already tested with different cable, and as info as well, this is more visible after 19h00.
During the day I get above 50Mg, altough is still far away from the 100, but after 19h00 it drops down to 10, or lower.
I am sending a picture of some measurements I took.
LAN Cable on my TV
It might help
Jens
Hello Joao,
when does the cablerouter lose the signal? And can you test the speed with a pc or laptop?
Regards
Jens
Hello
It is not regular. I was just arriving home, and it was going down, like making reset. This happens a few times per day, like the connection would all go down.
I already tested with my PC, and the behavior is variable. Sometimes over 50mg, sometimes below 10.
Thanks
Joao
I did not get any feedback about my problem.
How can I get some help, please?
The contractual conditions are not applying at all, and I have several breaks on the connection every day.
I need one solution, and technical support line is not able to help me in English.
thanks
Joao
Wallace
Hi Joao,
I'd like to check the line. Send me your customer data (name, address, customer number) in a private message and then let me know here that you have transmitted the data.
Regards
Wallace
Just replied privatelly as requested
Thanks
Joao
ERFD
it looks like a glitch on the way back. Does the signal always break in at 7pm?
Greeting Fred
Morning
Yes, it is starting from 19h00-19h30 and it stays "low" until around 22h30.
Thanks
Joao
