am 05.05.2018 09:37
am 05.05.2018 10:35
I've never saw what I was signing
And that will be the problem! You signed! I am not sure, if the Moderators can help. I hope for you.
am 05.05.2018 11:10
@rickstavares@ schrieb:
I hope to get this figured out, but if I don't I'll really need a help from some moderator to get the physical store-made contracts from the 04.05.2018 cancelled.
In addition to what @Gelöschter User already mentioned - that's the second problem:
There is no right to cancel those contracts made in physical stores...
So you have to ask the store to cancel those contracts as you were not aware that you have got two additional contracts.
By the way: Did you receive anything (SIM / Devices) from those other contracts? If not, ask the store in written form to give you all the things that belong to your contracts - not that anyone else is using the contracts that you have to pay for.
am 05.05.2018 11:15
am 07.05.2018 08:43
Hello @rickstavares,
sounds very bad what happened to you.
But just like the other already said this issue must be solved with the shop.
regards,
Boris
