am 22.10.2018 14:22
Hello everybody,
I have a mobile contract for months and now I also have Kabel from Vodafone at home.
In the login area it's only showing my mobile contract, so I tried to add the Kabel. When I type everything and go to the next step I get an error message:
Entschuldigung, da ist was schiefgelaufen.
Bitte versuchen Sie es später noch einmal.
Is there any solution for this? Already tried many times, since last week.
Thanks.
am 22.10.2018 20:40
Hi tibelchior,
our systems were down. Please try again.
Regards
Thomas
am 22.10.2018 20:40
Hi tibelchior,
Regards
Thomas
am 23.10.2018 00:28
Ok, now it worked. Thanks for the help! But when I try to access anything from this contract, it shows as I don't have.
am 23.10.2018 14:48
Hi tibelchior,
is the cable contract already active? If so, you should be able to add it.
Regards
Thomas
am 23.10.2018 15:11
Today it was working fine. I think it just takes some time to show everything in there.
am 23.10.2018 17:26
Hi tibelchior,
very good. ![]()
Do you still have questions or can the post be closed?
Regards
Thomas
am 23.10.2018 18:46
No, it's ok. You can close it.
Thanks
