Archiv_Internet-Geräte
FritzBox 6490 Kabel Bridge Mode (EN)
My cable connection was finally installed today, and I want to set up my Fritz Box in Bridge Mode so I can use my Linksys router as my main router, while my FritzBox is used only as the modem.  Based on other posts I see that this is not possible with the Fritzbox from KD.
What are my options to switch to an option that supports bridge mode? My current tariff is Red Internet 400
6 Antworten 6
Moderator
Hello, pdmccart,
You are welcome to cancel the Fritz!Box option. You will then receive a cable router and you can set it to bridge mode.
Greeting Fred
Alles Easy How To Hilfe !
Thanks Fred.  Is it possible to keep the FritzBox until I receive the other cable router? I need to maintain the internet connection as I work from home.
Moderator
Hello, pjack3191,
of course you keep the Homebox until you have the other modemSmiley (zwinkernd)
Should I initiate further requests or do you want to call the hotline yourself?
Greeting Fred
Highlighted
Hi Fred,
That would be great if you could initiate the requests, thanks!
Moderator
Hello, pjack3191,
so that I can remove the Homebox option from your site, I need your customer number and address by private message.
Greeting Fred
Moderator
Hello, pjack3191,
I deleted the option home box. You will receive the cable modem within the next few days.
Please send the Fritz! box back to us. Once you have successfully connected the residential modem.
Greeting Fred
