Archiv_Internet-Geräte
Siehe neueste
[English] Request to enable IPv4 for port forwarding
MehdiA
Dear Administrators
I am a new Vodafone cable user; My modem is "Sagemcom FAST 5460"
I need to do port forwarding to be able to expose some services of my Raspberry Pi to internet.
Unfortunately it seems it's not possible now (because of DS-Lite?)
I found topics which some Vodafone support personell have helped members with a similar problem recently.
Can you please help me switch to IPv4? (I really need the port forwarding, and at the moment, I don't have another modem/router)
Thank you in advance
Ins korrekte Bord verschoben!
6 Antworten 6
andreasabaad
Hello @MehdiA
Then it's time to convert your home network to Ipv6,
activate the Bridgemode by using your own router,
to use your own cable router,
or to switch to a business agreement with IPv4 as a contract component.
IPv4 is no longer so easy to serve. Contract condition is an access to the Internet, which also works on DS Lite without any problems!
MehdiA
Thank you very much for the reply.
I haven't decided whether to switch to Business. (I'm not even sure how difficult it is to switch)
For your first suggestion, I need something like a FritzBox, right?
MehdiA
To enable bridge mode, you should first disable "home spot" from "Internet Settings" in "Mein Kabel" and it says it takes 7 days to disable it.
I don't know why it needs so much time to disable it, but it seems I'm stuck for a week!
Steffi
Moderatorin
Hello MehdiA,
premature deactivation of the home spot is unfortunately not possible.
regards
Steffi
Alles Easy How To Hilfe !
MehdiA
@Steffi Thanks for the reply. Now that my hotspot is de-activated, I can enable the bridge mode.
So, I need something like Fitzbox 6490. Right?
Steffi
Moderatorin
Hello, MehdiA,
You can connect your own W-Lan router behind the Sagemcom FAST 5460.
regards
Steffi
