am 27.02.2020 09:25
Hello
I have activated by mistake the Hotspot Service for my new 1Gbit connection in Vodafone Internet settings page, forgetting that it will take me 1 week to be able to deactivate it again. Is there a way someone from Vodafone support can help me to deactivate Hotspot manually! So that I can use it in Bridge Mode. Thank You in Advance.
PS: I can send my private details in a private message upon approving.
Firmware-Version: 1.0.9-IMS-KDG
Product name: CGA4233DE
am 28.02.2020 10:02
Kann jemand mir bitte wenigstens auf meine Frage beantworten?
Vielen Dank
am 01.03.2020 14:45
Hello, Abbara,
since this is a customer help customer forum, the answer may sometimes take a little longer.
Unfortunately, there is no possibility to deactivate the hotspot prematurely.
Even if we do it from here, it will take 7 days
Best regards, Martin
am 01.03.2020 16:10
Hello Martin,
Thank you very much for your reply, I totally understand that. The strange thing is that I can't open any port after enabling this Hotspot mode and now I can't access my self hosted Bitwardenrs application also Syncthing really slow due to port 22000 is closed and finally can't use Direct play on PLEX due to port 32400 also closed, that's why I was eager someone help. I have no choice but to wait until 03.03.20, so I can turn it off. Thanks again.
Regards.
am 02.03.2020 17:48
Hi Abbara,
I'm sorry, I can't give you any other information. Unfortunately, the process cannot be accelerated.
Does your connection work as usual?
