An error occured! templates/dsl-kabel/_help.html (No such file or directory) java.io.FileNotFoundException: templates/dsl-kabel/_help.html (No such file or directory) at java.base/java.io.FileInputStream.open0(Native Method) at java.base/java.io.FileInputStream.open(FileInputStream.java:213) at java.base/java.io.FileInputStream.(FileInputStream.java:152) at clojure.java.io$fn__11655.invokeStatic(io.clj:232) at clojure.java.io$fn__11655.invoke(io.clj:232) at clojure.java.io$fn__11607$G__11561__11614.invoke(io.clj:72) at clojure.java.io$fn__11629.invokeStatic(io.clj:168) at clojure.java.io$fn__11629.invoke(io.clj:168) at clojure.java.io$fn__11568$G__11557__11575.invoke(io.clj:72) at clojure.java.io$reader.invokeStatic(io.clj:105) at clojure.java.io$reader.doInvoke(io.clj:89) at clojure.lang.RestFn.invoke(RestFn.java:413) at clojure.lang.AFn.applyToHelper(AFn.java:154) at clojure.lang.RestFn.applyTo(RestFn.java:135) at clojure.core$apply.invokeStatic(core.clj:669) at clojure.core$slurp.invokeStatic(core.clj:7089) at clojure.core$slurp.doInvoke(core.clj:7089) at clojure.lang.RestFn.invoke(RestFn.java:413) at sc.vodafone.website.pages.may22.templates$render.invokeStatic(templates.clj:10) at sc.vodafone.website.pages.may22.templates$render.invoke(templates.clj:6) at sc.vodafone.website.nav$render.invokeStatic(nav.clj:118) at sc.vodafone.website.nav$render.invoke(nav.clj:106) at sc.vodafone.website.html_export$nav_page.invokeStatic(html_export.clj:29) at sc.vodafone.website.html_export$nav_page.invoke(html_export.clj:25) at clojure.lang.AFn.applyToHelper(AFn.java:154) at clojure.lang.AFn.applyTo(AFn.java:144) at clojure.core$apply.invokeStatic(core.clj:667) at clojure.core$apply.invoke(core.clj:662) at shadow.server.http.core$call_handler.invokeStatic(core.clj:161) at shadow.server.http.core$call_handler.invoke(core.clj:158) at sc.vodafone.website.html_export$http_root.invokeStatic(html_export.clj:52) at sc.vodafone.website.html_export$http_root.invoke(html_export.clj:50) at clojure.lang.AFn.applyToHelper(AFn.java:154) at clojure.lang.AFn.applyTo(AFn.java:144) at clojure.core$apply.invokeStatic(core.clj:667) at clojure.core$apply.invoke(core.clj:662) at shadow.server.http.core$call_handler.invokeStatic(core.clj:161) at shadow.server.http.core$call_handler.invoke(core.clj:158) at sc.vodafone.website$root.invokeStatic(website.clj:656) at sc.vodafone.website$root.invoke(website.clj:650) at shadow.server.http.core$do_request.invokeStatic(core.clj:840) at shadow.server.http.core$do_request.invoke(core.clj:836) at shadow.server.http.core$do_ring.invokeStatic(core.clj:858) at shadow.server.http.core$do_ring.invoke(core.clj:844) at sc.vodafone.system$get_ring_handler$fn__28838.invoke(system.clj:420) at ring.middleware.file$wrap_file$fn__28579.invoke(file.clj:50) at ring.middleware.content_type$wrap_content_type$fn__28613.invoke(content_type.clj:34) at org.httpkit.server.HttpHandler.run(RingHandler.java:91) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:572) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:317) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1144) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:642) at java.base/java.lang.Thread.run(Thread.java:1583)
Nicht alle HD Sender entschlüsselt
roach13
Guten Morgen,
Ich bin umgezogen und wohne jetzt in einem mehrparteienhaus. Dort gibt es den grundversorgungs TV gruppenvertrag mit Vodafone Kabel.
Um die privaten HD Sender gucken zu können, habe ich mir die Smartcard mit CI+ Modul kommen lassen.
TV ist ein neuer LG OLED65C17LB.
Modul mit Smartcard ist drin und pro 7 HD, Kabel 1 HD, sat 1 HD, Welt HD usw. gehen alle.
Seltsamerweise gehen RTL HD, RTL 2 HD und Vox HD nicht. Hier bleibt die Meldung bestehen, dass es sich um einen verschlüsselten Sender handelt. Somit kann ich die nur in SD (Augenkrebs^^) gucken. RTL Crime HD geht aber wiederum.
Jemand eine Idee, was hier das Problem sein könnte?
Danke 😊
roach13
@Stephan
@Peter165
Ich habe heute endlich ein neues Modul bekommen. Dies mit der aktuellen bootloader Version 1.1.3
Damit gehen alle Sender problemlos. Somit lag es am veralteten Modul, obwohl der telefonische Support das nicht als Problem gesehen hat.
Ende gut alles gut 👍
Danke für eure Hilfe 😊
26 Antworten 26
Peter165
@roach13  schrieb:
Seltsamerweise gehen RTL HD, RTL 2 HD und Vox HD nicht. Hier bleibt die Meldung bestehen, dass es sich um einen verschlüsselten Sender handelt. ... RTL Crime HD geht aber wiederum.
Hm, um ehrlich zu sein ich finds seltsam das RTL Crime HD geht.
Weil das alles Sender der RTL Gruppe sind.
Ne mögliche Ursache könnte die Modulsoftware sein, das jene veraltet ist.
Die Meldung " verschlüsselter Sender" deutet darauf das be den Sendern das MOdul nicht erkannt wird.
Welches CI+Modul nutzt du?
Ja das mit RTL crime wundert mich ebenso. Das macht irgendwie keinen Sinn.
Modul das ist das Originale von Vodafone, vor ca. 2 Wochen bekommen.
Ggf. Nochmal Sendersuchlauf machen?
Firmware vom TV konnte ich mangels Internet noch nicht aktualisieren.
Welches, VF hat bei exKD 2 unterschiedliche CI+Module, bei VF exUM wird ein anderes genutzt.
Nein, das meinte ich nicht, sondern die Software für das C+Modul, das kommt übers Antennenkabel.
Die Aktualisierung der TV Software, auch ein Gedanke.
https://ibb.co/rw9w2JP
https://ibb.co/RH0y85Y
https://ibb.co/LQYftZR
Link entfernt wegen Erkennbarkeit der Seriennummer
https://ibb.co/Vt1wfXV
Hab dir Fotos gemacht, hoffentlich hilft dir das weiter. Neue Software fürs Modul wie ersichtlich nicht gefunden.
Danke für die Fotos, aber da stellt sich mir die Frage was für uraltes CI+Modul dir da VF KD geschickt hat?
Es ist ein Smit CI+Modul für VF KD.
Modulsoftware (3.0.9) wie Bootloader (1.1.1) sind ja uralt, möglicherweise ist der alte Bootloader die Ursache warum da keine neue Software gefunden wird.
Aktuell wäre 3.3.3.2 L12 für die Software und für den Bootloader 1.1.3. So mein Wissensstand.
Was steht hinten auf dem Modul neben P/N: RET BTLDR... oder KDG BTLDR...?
Siehe foto
Link entfernt wegen Erkennbarkeit der Serienummer
Also gleich mal beschweren und ein aktuelles Modul fordern?
Danke Dir, ja das ist uralt.
Aber warum ein Foto, noch dazu mit Modulseriennummer?
Ich entferne diesen Link und auch den anderen Link wo die Seriennummer im Menü zu sehen ist, bitte darauf achten das Seriennummern nicht zu erkennen sind, das läßt sich mißbrauchen.
Im Prinzip ja, nur der dem du das schlilderst, der hat keinen Einfluß darauf was verschickt wird.
Ok, danke und sry 🙈
Also kommt möglicherweise wieder ein so altes modul?
Was würdest du in meinem Fall jetzt tun?
Auf alle Fälle es nochmals zu versuchen, ist zwar gut gesagt, aber irgendwann muß das ja mal klappen.
Ich hoffe mal nicht.
